Results 1 to 8 of 8
    Mga Paps,
    Napansin ko lang mabilis maubos ung coolant sa reservoir ko.
    my ride is mitsu advture 2012, then kakapalit ko lang ng coolant 2 months ago(40,000 checkup sa shell).
    Then I notice kalahati nalang coolant. Yung isa naming adventure 2003 model... 1.5 years punong puno padin.
    Anyone who experience this or is it normal na sa mga bagong labas...
    there can be a leak somewhere, or in worse case scenario, your coolant is mixed in your oil.
    any other symptoms? madumi ang radiator cap? milky oil sa dipstick? smoke?
    pero since the unit is still new, the probability of leaks lang sa hose ang mas mataas.
    imho.
    Sep 2012
    Binaklas ba yung upper and lower hoses ng radiator ? If yes nung binalik ba nilagyan ba ng RTV Silicone ?
    Quote Originally Posted by jodski View Post
    Hinde sir... nibleed lang... check ko ung singit singit
    update lang... nicheck ko kanina... malinis yung langis... malinis at malinaw yung tubig... no obvious sign of leak sa hose...
    Dec 2009
    Its not advisable to top-off the coolant..the proper level is between the max & min level
    Posted via Tsikot Mobile App
    Dec 2009
    Hindi kaya sa o-ring lang? Nung nagpalit kasi ako ng coolant nung 40k napansin ko agad na may leak. Nung na check o-ring yung diperensya.
    havent check other symptoms... check ko sir mmya..
    pero san banda yung O-ring sir...
Mabilis maubos na coolant sa reservoir - Adventure
