Results 1 to 7 of 7
    Mar 2011
    Bosch vs NGK vs Denso
    Mga sir NEED YOUR HELP lng po..
    Newbie lng po aq sa CARS 1st car q po kc to LANCER GSR BOXTYPE.
    Advice lng po sna kung anung Best sparkplug for LANCER BOXTYPE? HELP lng po. Thanks!
    Jan 2011
    Chief IMO;
    if you have the budget, go for Bosch
    if you want to be practical, NGK
    Been using NGK on our '02 Lancer pizza and it's a bang for a buck talaga. Most mitsu casas were using it back then when it was still under warranty. As long as you religiously follow the manufacturer's recommended interval for changing spark plugs (tune-up nadin!),then, IMO, your box-type gsr is as good to go w/ the latest models even with NGK spark plugs.
    Mar 2011
    Ah ok tnz sir.. Well appriciated! E sir ques lng po ulit. Sa bosch wt sparks mganda? Latest din?
    Feb 2009
    Sir IMO,
    NGK or DENSO pa din. Mas mahal sila sa BOSCH at sila ang OEM ng mga japanese makes. I myself use NGK pero nung minsan binigyan ako ng uncle ko ng BOSCH kaya yun na lang sinalpak ko, libre e. hehehe.
    Para sa lancer box type.
    Kung Lancer NGK hanapin mo . Bili ka doon sa mga reputable na suking auto supply mo . Marami rin fake na lumalabas lalo na pag mura presyo magduda ka na.
    Feb 2009
    Tama! Eto basis ng SRP para nde ka malinlang.
    WR8DP usually goes for php140 a piece
    BPR5EGP usually goes for php155 a piece
    Feb 2009
    Sir IMO,
    Mag platinum plugs ka na lang siguro sir kasi mas mahaba buhay nila plus mas ok ang sunog. NGK = BPR5EGP or BOSCH = WR8DP.
    Hope this helps.
Best sparkplug
