Results 1 to 12 of 12
    A friend of mine owns an Adventure diesel (4D56). He had a wild idea of salvaging an old turbocharger/intercooler from a 4D56 surplus engine and placing it sa engine niya. Do you think this is feasible?
    Thanks.
    Iba yata ang specs ng 4d56t (ur engine) sa normally aspirated na 4d56(adventure's engine) It can be done, but after a few months, KABOOM! :mrgreen:
    But i might be wrong, let's wait for the cpmments of other tsikot peeps.
    yes it can be done.
    but i suggest since he will buy a surplus engine that he install the whole engine and keep the original engine just in case the surplus engine will give up already or when time comes to sell the vehicle balik niya sa original.
    there a lot that doing it here in our place, may nissan pathfinder na ka turbo from a td27T turbo engine, he took out the manifolds I/E, and turbo and installed it sa orig engine niya. may nissan patrol man na naka turbo taken from a Fuso engine na 4D32. and a lot of hi-luxes na turbo taken from 2L-TE. may isa nga pathfinder also turbo from a SR20DE engine.
    the key in converted turbo is boost, you limit the boost to around 7-8psi only, so as not damage the internals of the engine.
    Mar 2003
    Quote Originally Posted by ARB
    yes it can be done.
    yep, that's the safest way to go
    iba ang internals ng 4d56 and 4d56t.
    This can be done, and tama sila, its better to replace the whole engine. kaya lang mahirap humanap ng 4D56TDIC. Marami Yung 4d56Turbo.
    Pero oks yang idea na yan!
    Iba po ang sukat ng piston, types of metal used and other parts ng N/A, Turbo, TDIC engines.
    me kakilala ako dito, yung adventure nya pinakabitan ng turbo, di ko alam kung naka ilan months, palit makina. tapos binenta narin yung adventure.
    Signature
    For sure, iba ang piston rings ng N/A at ng Turbo versions. I recall nung bumili ako ng parts for my overhaul, iba part no nila.
    Im just not sure about the other parts.
    Quote Originally Posted by pajerokid
    Pati sa piston iba rin bossing. :D Lalo na sa sukat malaki ang pinagkaiba.
    Ungas, ah k. di pa kasi ako nakkakita ng pistons side by side... :D Siguro mas matangkad or makapal yung pang turbo.... kasi pareho lang ang bore and stroke nila eh afaik....
    pajerokid::: Di ko rin alam dati, nalaman ko lang nung inoopera makina ni ser Larry, ngayon kay boss NightRock na pala. :D
    tama sila engine swap na lang, and yup mas maganda kung TDi
    ask yellow and woodfire nag swap na sila ng engines
Intercooled Turbo Adventure?
