Results 1 to 7 of 7
- Jun 2012
- 5
June 30th, 2012 09:14 PM #1pansin ko sa EL ko, hirap humila pag tama ang timing. chineck ng mekaniko gamit ung timing light. tama ang timing. pero hirap humila, kailangan laging madiin sa gas. kaya siguro malakas sa gas, 10 km/liter average. inadvance ko, wala namang tope, ganda humila. konting tapak sumisibat na. di ko pa pansin ang konsumo di pa ulit kasi ako lumalayo. ok lang ba to, na advance ung timing ko kung hindi naman tumotope?
- Jun 2012
- 5
July 1st, 2012 12:19 AM #4
ganito yan eh kung replacement timing belt nilagay mo tiyak na hindi matitiming ng perfect yan sa crankshaft at camshaft. mag aadvance or retard ng 2 or 3 teeth sa timig belt depende sa pag install ng timing belt, 3 teeth malayo masyado
- 54,293
July 1st, 2012 09:47 PM #5i think what he is saying, is that the timing gears inside the engine have first to be adjusted correctly by the mechanic working on the engine. this is usually adjusted only once in a long while, as when replacing timing belts or chains. if this adjustment is done incorrectly, then there is no way anyone can adjust external timing on that engine, which is what you are attempting to do.. also, it can result in (if it hasn't yet) engine damage..
btw, 10 km/li isn't all bad..
- Jun 2011
- 130
July 7th, 2012 02:10 PM #6
- Jun 2012
- 5
July 17th, 2012 11:44 PM #7hinigpitan na ang cable, tune up, retiming. sumigla ng konti ang takbo nya. but still makupad, inoobertakean ako ng mga bastos na jeepney driver, hindi ako umaabot pag sabay kaming umarangkada! tsk tsk. to make matters worse, malakas sa gas. 145 km round trip bulacan-manila, ubos ang P800.00 ko! mga 9.14 km/liter, masakit sa bulsa, saklolo! or else mapipilitan ako na mag- kia pride ulit. mabagal man, mabagal din maubos ang gas
kahit heavy traffic sa manila, hindi bumababa sa P14 km/liter...
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
