I think pag on yung light ng glow plugs sa instrument panel, that means the glow plugs are also on, if the light's off the glow plugs are off as well (correct me if I'm wrong). So in a normal working situation, your Adventure can be started na pag off na yung light sa glow plug indicator and it
should start. Sa kin dati pag ayaw mag one-click start, (maybe one of the glow plugs are dead) ilalagay ko sa "acc" yung susi then back to "on" position then repeat it again tapos it will start na. Nung hindi na gumagana yung method na yun (probably two or all of the glow plugs are dead) binobomba ko na ng paulit-ulit yung gas pedal while cranking with the starter, after a few seconds start na sya. Pero I don't recommend that because your cylinders will be drowned to death and your battery will be discharged kung ibababad mo ang starter. Pero I did that several times and fortunately the engine starts.
