Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    Feb 2004
    mga peeps need help po..
    yung freind ko recently got his pajero, jap convert automatic. he notice na yung front indicator ng 4wd sa dash nag bli-blink so ginawa natin nag reverse kami to dis engage yung hubs pero hindi pa din nag off yung indicator. inulit namin na mag 4WD at naging steady naman yung indicator light pero pag balik sa 2WD blink lang ng blink kahit nag reverse na. ano po kaya problem non at paano aayusin.
    second yung gear change parang hanggang 3rd gear lang, ayaw mag 4th gear, related po ba ito sa problem sa 4WD o iba pa ang cause.
    thanks ng marami sa tulong
    Baka may problem ang vacum or solenoids niya. Best thing to do is have it checked by Joseph Atutubo (resident Pajero expert).
    In the meantime, keep it in fulltime 4wd mode ("4H"). This will prevent any further damage to the system as the system is in it's 'relaxed' state at 4H.
    The Pajero system is unique in the sense that it's default mode is all wheel drive. It can only go to 2wd by 'forcing' itself (via vacum and solenoid action).
    In 4H, you are running in a mode no different from a Toyota RAV4.
    4HLc and 4LLc are strictly for offroad use only.
    As for the tranny, baka hindi gumagana ang overdrive niya. There is a button on the side of the shifter for that. Baka hindi naikabit ang wiring ng maayos. Overdrive is equivalent to 4th gear.
    Feb 2004
    tamang tama si otep. i replaced on of my solenoids already when my front indicators kept blinking.
    Otep, have you replaced your solenoid na. hwag ka kumuha ng solenoid sa casa, sobrang mahal. maybe joseph can source out some that don't cost what the casa is charging.
    andy
    magkano yung solenoid na ito? just out of curiosity
    May 2004
    oi ganyan samin.. pinalitan ata ung hub lock ba un nga tatay ko nag stick sa third gear ung jap converted namin.. pero binalik ung orig nag tuloy na sa 4th gear ulit.. ung blinking center diff ayaw talga mawala eh pero la naman kaso.. sanay narin kami na nagbiblink unÜ
    Aug 2003
    hi all, thanks for all the replies and thanks jay101 for creating the thread.
    Just got back from the talyer and they said they've asked around subic, sa mga mekaniko doon and they said that baka OVERDRIVE CLUTCH yung may problema. Ang sabi sa amin Iangat namin yung rear and then patakbuhin namin, kapag swabe yung kagat ng downshift kapag in-off yung overdrive then itesting namin kung the same ang kagat kapag tumatakbo sa kalye. Kapag ok daw na nakataas and hindi kumagat kapag nakababa ibig sabihin daw po na nahihirapan kumagat yung clutch ng OD and most likely stuck-up na yun, which ganun na ganun nga po ang kinalabasan.
    Ibababa raw nila ang tranny para i-tsk nga yung OD clutch, yun nga lang waitlisted pa kami sa tranny expert na kilala noong shop. Kaya eto po ako ngayon wala na namang sasakyan (bitin!)
    Yung blinking ng 4WD, nagkita na po ni Joseph we got to meet last Sunday morning baka kailangan daw pong linis ng solenoid. Bait po sobra nilang dalawa ng dad nya. Nice meeting you both po. Hopefully kung maayos yung tranny tuloy kami sa Sabado to fix the blink-blink if not, resched.
    thanks for all your replies. Will keep you posted kung naayos nga...
    Feb 2004
    PK, nasa kotse ko pa ang statement of account ng casa. mahal kasi sila, so binabawian ko na lang ng cost of money hehehehe
    march pa yung utang ko doon. siguro this month, bayaran ko na
    tagal naman tumama ng lotto.
    andy
    luckytruck/andy,
    Somehow my 4wd system has a 2wd mode again. Mga 3 days na kong naka 2h and ok naman. Sana tuloy tuloy na ito.
    On a side note, I tore both my inner half shaft boots. I'm looking for a bigger boot to compensate for the steeper driveline angles due to my suspension lift.
    Feb 2004
    otep, i hope those boots are not like the axle boots of the F150. i tore one of mine dati. 12,000 ang replacement sa ford. sakit
    andy
    Andy,
    Replacement boots for Japanese vehicle cost less than Php 300.00 for a non-OEM part. hehehehe.
    Feb 2004
    otep, tama nga yung decision ko to shift to a japanese vehicle
    andy
    Aug 2003
    sir chokers, saan po kayo nagpaayos ng hub lock at magkano po inabot? tinry ko po paayos yung tranny, may mga pinalitan daw na mga piyesa, binaba raw po kaso ganun pa rin. mukang di talaga doon. medyo duda na ako sa mga nagaayos, baka mas maigi pa pa-tsk ko yung hub lock pareho noong sa inyo.
    mga peeps, anyone can recommend a good shop na nag-aayos ng hub lock dito sa south (i live in sta. rosa laguna)? baka doon nga po sira rin noong sa akin kaya ayaw mag 4th gear.
    maraming maraming salamat in advance.
    Jun 2004
    mga master tanong lang po kung yung 4H ng 1st & 2nd gen Pajero eh 50/50 yung ratio kagaya ng AWD salamat po..>>
    Jun 2004
    mge ser....pasencia na po sa OT..di ako makahanap ng thread e...
    alam nyo po ba ang fuel tank capacity ng Gen1 Paj? (wala akong manual e)
    Salamat!
    Nov 2006
    Quote Originally Posted by pparado View Post
    Salamat!
    Kung 5dr yan 90 liters ang capacity nyan!
    Nov 2007
    ang pagka alam ko dyan hindi talaga pwedng itakbo ng mabilis ang 4wd ng pajero subic"?
    yung sa bro ko dito sabay nag bblink ang indicator ?normal ba yun?
    Jun 2004
    Salamat!
    if i remember correctly its 60 liters. i'll double check the owners manual later.
    Feb 2004
    check on the thread that states "pajero expert" i am sure he will be the one most people recommend to help you.
    as for tank capacity, i think the gen 2 is 80 liters ++ (maybe they didn't change from gen 1 to gen 2)
    on the gen 2 pajero, they have such a thing called super select 4 wheel drive which uses a center differential that is not locked (unles you go lock it wiht the shifter) so the power is distributed betweeen front and rear as needed.
    maybe the other pajero owners can elaborate
    andy
    Feb 2004
    mga sir, 92 liters po ang capacity ng gen 1 pajero ( local )
    Feb 2004
    naku, mali ata and sinabi kong 80++ liters ang gen 2. can anyone verify? i rarely top of my gastacnk kasi. puro 50 liters at a time lang.
    andy
help on pajero 4wd
