Results 1 to 19 of 19
    Guys,
    Need Help... the fuel gauge of my adventure suddenly won't work...... tried gassing up but still the needle didn't move. What do you think was the cause of that? Has anyone experienced the same thing? What other checking do I need to do before bringing it to the repair shop?
    Hoping for your reactions. Thanks
    1 possible culprit could be the "float" in your gas tank got stuck.
    Apr 2005
    kung yong needle goes down to zero, malamang tama si sir Falken, bago yong float valve sa gas tank.
    Kung stuck up yong needle , malamang yong gauge ang defective.
    Pacheck mo sa competent mechanic.
    Oct 2005
    sa akin din hindi na rin tumataas! mahal na kasi krudo kaya tipid-tipid!
    Apr 2005
    Quote Originally Posted by eurie
    hahahahaha!!!
    IMO, Defective float
    Oct 2005
    Quote Originally Posted by arvic
    hahahahaha!!!
    ako defective wallet!
    Oct 2005
    defective float valve. my friend had an adventure na ganyan din ang sira.
    Guys just found the problem. It turned out that the fuel gauge wire under the chassis was ripped off by my dog. Watch out for this if your dog usually stays under the car. Anyway, it was reconnected and the fuel gauge worked.
    Thanks for those who replied.
    Sep 2004
    Quote Originally Posted by justin_1179
    bad dog..bad dog...
    Apr 2005
    MAD DOG!!!1HEHEHE
    Apr 2005
    kawawa naman yong dog, napag interesan kainin yong wiring, huwag sana siyang pag-interasan galing pulutan.
    Floater yan... had mine replaced a year or two ago. Replacement part instead of orig will do.
    Aug 2006
    e panu pag nagloloko ung gauge nya., minsan nasa baba minsan nasa taas,. tska ndi gumagana ung fuel emergency light nya.,
    Sep 2006
    Ako din po fuel gauge problem din. Kahit po i-full tank ko ayaw sumagad nung needle. At hindi ko po alam kung gumagana pa ung emergency fuel lamp, kaya po estimate lang po kung kelan ako papa-gas uli. Takot po ako sagarin ung gas, sabi ng erpats masama daw matuyuan po, kaya pag nakita ko ng tumakbo ako ng 300kms after one full tank, pa-gas na po uli.
    Any reactions po? Salamat.
    Dec 2004
    Quote Originally Posted by nat2x View Post
    pareho tayo. ganun na ganun din yung sakin. minsan bagong karga pa ng diesel at saka nasa baba yung needle. san kaya ok na i-pacheck ito na mura lang ang singil?
    Jun 2005
    My former car had only two readings. If the tank was more than half, the gauge read full tank. If less than half, empty.
Defective fuel gauge
