Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Dec 2016
    Hello All,
    Good Day! Admin pakidelete nalang kung meron ng query regarding dito pero wala kasi ako makita eh. As my first upgrade sa Mirage G4 GLX ko, i am planning na magLagay ng foglamps sa unit ko. since malapit na ang tag-ulan, planning to have my Headlight upgrade to HID (4300k) siguro then foglights na Super Yellow (3000k). ano take nyo dito? ok ba tong combination na to? anong wattage ba dapat? thanks!
    Quote Originally Posted by kamotekid1968 View Post
    Hello All,
    Only get HID upgrades if your headlights are properly retrofitted with projectors. Having said this, you can go with Osram Nightbreakers and Fogbreakers respectively. These are halogens and can make use of your existing headlight and foglight assemblies.
    Dec 2016
    thanks sir *ssaloon, sorry di ako masyadong technical sa sasakyan ah? newbie kasi. pagkakaintindi ko, OSRAM brand gagamitin ko, NB for headlights ko at FB para sa fogs ko? ang tanong ngayon, diba may mga Kelvin-Kelvin pa yan sila na nalalaman? anong combination kaya maganda? balak ko kasi super yellow sa fogs ko para pag maulan, di mahirap sa kalsada at medyo yellowish (4300k) para maliwanag at pag di maulan ok sya.
    Quote Originally Posted by 1968 View Post
    Hello All,
    it is laudable that TS is thinking of his safety.
    i do hope that, when the time comes, the oncoming motorists are not blinded by his radiance.
    Dec 2016
    hi sir *dr. d, the reason behind this is, though di malabo ang mata ko (20-20) vision pa naman, pag naulan kasi lalo't malakas, hirap sa kalsada ng stock na headlight gamit ko, wala pa akong fogs para sumuporta. di ko din naging ugali ang mag-HI ng ilaw ko especially pag salubungan ang kalsada...nahihiya kasi ako sa kasalubong ko at i respect them. sa amin, coming from Deparo Caloocan, going to Novaliches palabas ng Sauyo eh napakadilim ng mga kalsada, lalong hirap pa pag bumuhos ang malakas na ulan samahan mo pa ng foggy na windshield.
    i understand, po.
    my concern is, the upgrade may be advantageous to the upgradee, but its glare might be detrimental to the oncoming motorist.
    i am simply wishing, that upgrades should also include proper shielding against glare, even if it is the more expensive way to go.
    my theory is,
    with standard bulbs, stray light ("glare") is too weak that oncoming motorists are not bothered by this stray light.
    but once the light source is upgraded, the stray light becomes much stronger, and is now going to affect the oncoming motorist. in this instance, reflectors should also be upgraded, to "tame" the light beam into a tighter direction.
    Dec 2016
    ang naiisip ko lang is, say i will upgrade my bulbs sa mas malakas na ilaw...siguro we just have to make sure na tama ang "tutok" ng ilaw at di nakakasilaw sa kasalubong na sasakyan. kung madami lang akong pera, sana nagprojector na ako..hahaha!
    i have been driving for over 25 years.
    and one thing i have to keep telling myself. "if you have to use your lights, it means you should also drive more slowly".
    those roadway speed limit reminders on the road, are meant for bright daylight or ideal driving conditions.
    Jun 2005
    From experience, yung tinitinda na fog lamps sa market at pure porma lamps only.
    Kung pinaandar mo na, useless. Halos walang difference.
    For your HL, stick to stock wattage. Yung HID plus reflector combo puro glare sa kasalubong. Kawawa naaman. Kahit anong adjust mo nyan, silaw kasalubong mo. Kapag tinutok mo naman pababa, silaw pa din sila pero ikaw walang makita.
    Kapag mag HID ka, need mo muna palagay ng projectors para lahat ng ilaw nakatutok sa daan at hindi sa mata ng ibang motorista
    Jun 2005
    About color temperature, AFAIK stock factory lamps are 4000k. Night breakers are around 4300k. The lower the number, more yellow. The higher number, mas maputi/bluish.
    Mas visible ang 4300k na color temp. Yung mga 5000k and up, maputi na. Tried both 5000k and 6000k on my projectors. Di ko gusto. Puro shadow lang nakikita ko. Returned to 4300k
    Dec 2016
    sir *sirkosero, having said that, it is safe to say na ok ang combination ng HL (4300k) at fogs na (3000k, super yellow). super yellow para sa maulang panahon at kalsada then 4300k para sa madilim na kalsada
    Jun 2005
    Yung 3000k masyado na yan dilaw. Will work kung lagi ka nasa foggy mountains. In my old car, used a super yellow bulb for fog lamps. Nilagay ko din sa aftermarket fog lamp assembly.
    Ayun. Useless. Porma lang, sabog ilaw, nakakairita daw sabi ng nakakasalubong. From inside the car, kapag naka-on ang fog lamps, parang naka park lights lang ang dating kasi wala talaga dagdag output.
    Kapag naka on na headlights, lunod na ang ilaw ng fogs.
    Dec 2016
    wow! thanks sa inputs mo sir *sirkosero, so anong magandang combination then? both 4300k sa HL at fogs?
    Jun 2005
    Personally, stick to stock colors lang ako. That will be around 4300k.
    Pero you might want to consider all weather bulbs na din. I think osram din brand neto. Mas dilaw than stock pero mas maputi than super yellow
    Dec 2016
    yup! based sa mga napansin ko, ang 4300k ang best fit (for all weather) nga...maputi ito na medyo yellowish. so ok ang 4300k for both pala. may sinasabi silang H4, H7 at H11..i have no idea what they're referring to...hahaha!
    Those are bulb types dependent on the vehicle. Nasa manual yung applicable sa car mo.
    Dec 2016
    sir *ssaloon, wala akong makita na specs sa manual ko
    Jun 2012
    Sa Mirage ba? H4 ang headlamp.
    Jun 2005
    Iba-iba ang base ng h4, h11 h3, h1.
    Hindi kasya ang mga ibang bulb sa h4 housing
    Aug 2012
    Re: color temp. Osram Night Breaker Unlimited and Laser H4 are 3900K. Philips Xtreme Vision +130% H4 is 3400K.
    Sent from my ASUS_Z010D using Tapatalk
Best HeadLight and FogLamp coLor/Light combination
