Results 1 to 4 of 4
- 80
April 4th, 2013 02:38 AM #1taken from Mitsubishi Motors Malaysia
Field Fix Campaign for Mitsubishi Mirage
Campaign to replace Front Wheel Speed Sensor
... sa Australia meron naman nakatanggap ng recall notification
Description of Problem
Mitsubishi Motors Corporation has identified a condition that affects the front wheel speed sensors fitted to the Mirage vehicles.
Insufficient water proofing of the sensor harness may allow moisture to penetrate the sensor resulting in abnormal output signal.
This can result in ABS warning lamp illumination, speedometer needle deflection, ABS and TCL false activation and in worse case scenario, the braking force could reduce and/or the steering contorl could become unstable at the time of sudden braking from high speed.
meron na rin pala local Mitsu site
MITSUBISHI MOTORS CORPORATION | Press Release
check-out the link, you just need to enter your VIN number para malaman kung kasama unit mo.
- Oct 2012
- 73
Driver/PasaHERO
- 1,310
- Mar 2011
- 339
The hybrid release was also basically an all-new model release for TMPI, I think.
2021 Toyota Land Cruiser LC300
