Results 1 to 2 of 2
    Jun 2009
    While waiting for a proper attendance to your car, DO NOT TRY to start the engine, remove battery connection, If you have attempted in starting your car, cross your finger that the fuse absorbed the wrong diskarte,will be busted, thanks for that at na check ng fuse.When you have moved your car to a safer place, lagyan ng heater ang loob ng hood w/ incandescent lamp about 500 wats overnight or more but be sure it is not touching any burnable surfaces , mas maganda kung may na katotok na small electric fan. Buy a special spray for electrical that displace water or moisture then meticulously spray electrical connection especially ECU card. If you can't find this special spray, denature alcohol will do, be carefull there are some plastic react to this alcohol. the rest wait for the expert until they can attend your car.
    RTS
    [SIZE="3"]Kindly refer to the following discussion thread:
    NEED ADVISE: Vehicle/Engine submerged in flood water [MERGED]
    http://tsikot.yehey.com/forums/showthread.php?t=63374
    [/SIZE]
First Aid for drowned vehicles
