Originally Posted by
oj88
The answer to all your questions is "it depends".
Think of it as over/under-clocking your PC. On a desktop computer, this undertaking is no longer as simple as playing around with clockrates. You also play with voltages, multipliers, bus speeds, using faster-performing parts, better component coolers, etc. Do it right and you'll have a screaming-fast PC at a slightly lower cost. Do it wrong and the computer can get you from unstable, to unusable, to the smell of plastics burning.
ECU remapping is similar. It can give you better performance OR better fuel economy, or it can get you stranded in the middle of nowhere. Increasing performance will typically translate to a shorter lifespan of the engine and worse fuel economy. You typically counter the former by using aftermarket performance parts. There's no free lunch. The stock maps on the factory ECU are coded as such to increase engine reliability, lower emissions, and optimize fuel economy.
So back to your questions.... the end result of an ECU remap depends on the competence of the shop.
