Page 21 of 22 FirstFirst ... 11171819202122 LastLast
Results 201 to 210 of 215
    Aug 2004
    #201
    Magaan lang dapat yan kahit sa GLS na naka-Potenza.
    Jun 2015
    #202
    Maybe underinflated tires? Sa HB ko naman magaan pa rin 34 psi at makapal pa ang tread.
    Also, how's your tail/brakelight? It might sound unrelated but I've heard of some issues that were miraculously solved after replacing a busted brakelight.
    Social media made y'all way too comfortable with disrespecting people and not getting punched in the face for it. - Mike Tyson
    May 2018
    #203
    Quote Originally Posted by bxr monkey View Post
    Feather light din ang steering ng 2018 Mirage HB GLX ng relative. Although 165mm ang nipis ng gulong niya at naka 35psi factory spec.
    Baka kailangan nga pa check iyan, or baka makapal ang gulong or under inflated?
    I think I still have the factory tires, and 35 psi all around naman. Although recently I had both rear tires patched kasi napako. The heftiness of the steering isn't really affecting my driving. I feel like I'm just nitpicking.
    'Yun din ang iniisip ko lalo na these are factory tires pa.
    They're 35 psi all around. I had a busted brake light pero got it replaced already.
    Thanks everyone for the response. I tried multi-quoting but for some reason I can't figure it out for the life of me.
    Jul 2016
    #204
    Sira kaya yung lock sa kaliwang rear door ng mirage hatchback namin? ayaw gumana unless manually siya ilock at unlock. Naka deactivate naman din childlock. Tunog nga ng tunog alarm pag binuksan from the outside kasi di naglolock unless i manually lock mo sa loob. May sira ba yun o may namali lang ng setting or whatever mga magkano paayos nun kung sakali
    #205
    Quote Originally Posted by ratboy View Post
    Sira kaya yung lock sa kaliwang rear door ng mirage hatchback namin? ayaw gumana unless manually siya ilock at unlock. Naka deactivate naman din childlock. Tunog nga ng tunog alarm pag binuksan kasi di naglolock unless i manually lock mo sa loob. May sira ba yun o may namali lang ng setting or whatever mga magkano paayos nun kung sakali
    my two guesses,
    a connecting rod/plate dis-connected; or
    the solenoid/motor ain't working.
    you will have to open that door and find out.
    it's not that difficult, if one is comfortable doing that sort of activity.
    once opened, it's pretty straightforward common-sense troubleshooting.
    bring it to the mekanikos, if you prefer.
    my 2003 lancer cedia once had the same problem.
    the mekaniko replaced the actuating motor with a surplus unit. (motor pa noon, hindi solenoid.)
    Jun 2011
    #206
    Aabot din pala ng 40k CVT repair (comments section). Clutch repair kit pa lang. Ok pa ang belt and pulley.
    https://youtu.be/ycZNmlkIs3Y?feature=shared
    #207
    in comparison,
    when i had my 2003 altis 4AT repaired (at DNR), it cost me 21K.
    Jun 2011
    #208
    in comparison,
    Ano nasira po Doc, at ilan na tinakbo?
    Naalala ko 2000 gen 8 Corolla namin walang issue sa 4AT, until nabenta ng 2020 na 170k+ ang takbo.
    Drain and fill ATF every 40k.
    Palit filter strainer sa ~100k dahil nag leak na din oil pan.
    #209
    2003 altis 4AT, with over 100K km.
    hirap igalaw ang stick shift. ayaw pumasok kadalasan.
    overhaul kit ang binili, and it ate up over half of that 21K pesos.
    Jun 2011
    #210
    Kaka iba iyon ah. May na stuck siguro sa loob dati.
    Buti dumadami na din rebuild kit ng cvt ng common cars.
    Sa lazada pulley and belt set nasa 24k. Remanufactured lang ang pulleys, mukhang ni reface.
    TRANSPEED JF15E REF11A automatic transmission gear set with chain belt 9168 9172 Cvt pulley set for Nissan Mitsubishi suzuki car accessories [remanufactured] 29/3 Teeth | Lazada PH
Mirage - Issues/Problems?
