Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Oct 2013
    Differences between the 2013 from the current model. Pros and cons..
    Sent from my GT-I9505 using Tsikot Car Forums mobile app
    2014 mirage gls husay ng performance, saludo ako
    volts73
    Jan 2011
    Mdali daw masira un pindutan ng start engine sa gls? At anu pa?
    Walang bago. It's the same model. No facelift, no new features.
    Posted via Tsikot Mobile App
    May 2012
    2014 Specs Change:
    GLS
    1.Steering Wheel Audio Remote
    2.Usb Port and Aux Jack Located at floor center Console
    3.Side Sill Cover
    4. Tail Pipe Finisher
    GLX
    1. Usb Port and Aux Jack Located inside Glove Box
    2.Rear Speakers x2
    3.Power Doorlocks
    4. Tonneau Cover
    5. Power Adjust Side View Mirror
    6. Side Door Mirror Color Keyed
    7. Exterior Door Handles Color Keyed
    8. Side Sill Cover
    9. Tailgate Handle Color Keyed
    10. Keyless Entry incorporated
    Source:
    http://www.miragepilipinas.com/Threa...mirage?page=10
    Aug 2013
    Bakit walang door alarm yung G4 GLS? Ganun po b lahat ng mirage model?
    Sent from my iPod
    Sep 2004
    Quote Originally Posted by threadstone View Post
    Sent from my iPod
    Paanong walang door alarm? Tumutunog naman yung beep ng cabin when I open the door na nakasaksak pa yung KOS sa slot. Nagbi-beep din siya if I attempt to lock the doors from the outside with the KOS still inside.
    Aug 2013
    ang gusto ko sana is yung mag aalarm pag nauga ng malakas and kapag binuksan yung door handle ng hindi na unlock using yung KOS
    Sent from my iPod
    Mar 2004
    Check your system, maybe it's in Valet mode, if blue light is not blinking and always on when armed. You can also adjust the sensitivity of the alarm, it's located under steering column.
    Aug 2013
    check ko nga. yung blue light is always lit po.
    Sent from my iPod
    Aug 2013
    sir walter, pano malalaman kung naka valet mode? binasa ko yung manual ang hindi na mention.. saka di ko rin makita yung alarm adjustment.
    more queries btw:
    1. pwede b palagyan ng ilaw sa me gear ung GLS? hirap kc sa gabi, hindi reflectorized yung mga letters and ayoko nman nakabukas yung cabin lamp while driving at night.
    2. me nabasa ako sa manual re adjustment ng headlights depending on the number of passenger and load ng kotse. katabi sya nung button ng side mirror adjustment. bkit yung sa akin wala. there are 2 slots alloted btw. comments nman po dun sa mga me GLS ganito rin b yung sa inyo? il call my SA tmrw to inquire.
    Sent from my iPod
    Dec 2009
    more queries btw:
    Sent from my iPod
    The dashboard already have a gear indicator
    Sep 2004
    AFAIK, not every feature in the manual is included for the Philippine market. So yung things like stability control, seatbelt sensors and adjustable headlights, wala tayo nun. Naka-GLS din ako, BTW.
    We also get only two airbags, while certain markets have seven airbags.
    Aug 2011
    You could adjust your headlight setting manually. Buksan niyo ung hood then meron adjustment sa likod ng headlight. Kindy refer to your car manual.
    Aug 2013
    Normal po ba na me maririnig na parang "maganit" while trying to full turn the steering wheel after starting the mirage or any car in particular?
    yung sound is parang coming sa me unahan. bought the mirage 2-3 wks ago and it was smooth the first weeks. napansin ko lang ito kahapon.
    Sent from my iPod
    Aug 2011
    Mga sir affected pa kaya ng recall ( push start button and hard starting ) sa mga nakabili ng 2014 mirage?
    Aug 2011
    *threadstone - go to winterpine araneta sir. Lama nila kung paano reset yung alarm. Paturo na din kayo sa kanila.
    Aug 2013
    Quote Originally Posted by Tj_abs View Post
    thanks po
    Sent from my iPod
    my wife bought a 2014 GLS CVT.... slight upgrades from the 2013 as mentioned earlier... But I do like the OEM side skirt..not to big..just right to cover the underfloor door welts.
    Before buying, we compared to the WIGO, i10, Grand i10..and I must say, the GLS CVT is the best buy...The toys inside are worth the extra moolah on top of the GLX CVT, which wasnt much, when they offered an additional 20k discount on top of the 10K standard discount.
    It fits its purpose and more, very frugal at the pump, fun to drive, a torque hungry car when you need it.... etc..etc....
    Aug 2011
    Quote Originally Posted by petixs View Post
    Very true. Value for money and very fuel efficient. Inmo, the top of the line grand i10 is overprice compare to gls cvt but the grand i10 is more refine than mirage especially its nvh and handling. Im not sure lang sa fuel consumption ng hyundai and afterservice sales kung maganda.
Feedback for mitsubishi mirage 2014
