Results 1 to 7 of 7
    Feb 2011
    Mga sir i'm a newbie here hingi lang sana ako ng tulong sa inyo about my car kasi ganito po ang problem niya normally kapag nililiko mo ang manibela kahit hindi ka gumagalaw e wala namang tunog pero ung akin kasi merong sound na parang grinding sound hindi ko kasi ma-explain parang "grrrrrr" na check ko na rin yung power steering fluid meron naman po help naman mga sir tingin ko kasi parang hindi pumapasok yung fluid kaya ganun minsan naman nawawala kapag matagal nang ginagamit. Thanks in advance!
    Jun 2008
    Subukan i bleed ang hydraulic circuit ng steering system baka hangin lang yan. Possible rin na kailangan palitan ng original ang hydraulic hoses.
    Feb 2011
    Quote Originally Posted by weisshorn View Post
    sir weisshorn sorry ha? tanong ko lang pag i bleed ba sir anong process? sorry again sir newbie pa kasi basic lang alam ko or below basic pa hehehe. tyaka if ever magkano yung hydraulic hoses? salamat sir.
    Jun 2008
    Quote Originally Posted by Spoilt101 View Post
    Luwagan mo ng dahan dahan ang fittings ng steering fluid hose dyan sa puno ng gear box (rack and pinion assy) habang iniikot ang manibela na umaandar ang makina. Hayaan mong lumabas ang hangin hanggang puro fluid na lang ang lumalabas. Ingat baka mabigla at sumirit ng malakas, delikado mapunta sa mata. Don't forget to top up ang fluid reservoir.
    Check mo kung may yupi ang hose or any abnormal appearance. Possible kasi na minsan maliit ang internal diameter ng hose lalo na kung replacement kaya apektado ang volume flow ng fluid kaya kinakapos ang supply sa gearbox.
    Di ko alam magkano ang hydraulic hose para dyan, sorry.
    Hope this help.
    Did you change the power steering hose and used "replacement" hoses?
    Feb 2011
    sir ghosthunter negative, i think it's still original or should i check it out? how will i know if its a "replacement" hose? I'm the 3rd owner sir. Thanks!
    Just a guess since I am not too familiar with your car model, if it's original, it might have the mitsubishi logo and name stamped along the length of the power steering hose. If it's a replacement, it should have another name.
Help regarding power steering galant shark
