Results 1 to 10 of 31
- Dec 2016
- 208
April 28th, 2017 10:17 AM #1Hello All,
Good Day! Admin pakidelete nalang kung meron ng query regarding dito pero wala kasi ako makita eh. As my first upgrade sa Mirage G4 GLX ko, i am planning na magLagay ng foglamps sa unit ko. since malapit na ang tag-ulan, planning to have my Headlight upgrade to HID (4300k) siguro then foglights na Super Yellow (3000k). ano take nyo dito? ok ba tong combination na to? anong wattage ba dapat? thanks!
April 28th, 2017 10:26 AM #2
- Dec 2016
- 208
April 28th, 2017 10:31 AM #3thanks sir *ssaloon, sorry di ako masyadong technical sa sasakyan ah? newbie kasi. pagkakaintindi ko, OSRAM brand gagamitin ko, NB for headlights ko at FB para sa fogs ko? ang tanong ngayon, diba may mga Kelvin-Kelvin pa yan sila na nalalaman? anong combination kaya maganda? balak ko kasi super yellow sa fogs ko para pag maulan, di mahirap sa kalsada at medyo yellowish (4300k) para maliwanag at pag di maulan ok sya.
- 54,282
April 28th, 2017 10:38 AM #4
- Dec 2016
- 208
April 28th, 2017 10:43 AM #5hi sir *dr. d, the reason behind this is, though di malabo ang mata ko (20-20) vision pa naman, pag naulan kasi lalo't malakas, hirap sa kalsada ng stock na headlight gamit ko, wala pa akong fogs para sumuporta. di ko din naging ugali ang mag-HI ng ilaw ko especially pag salubungan ang kalsada...nahihiya kasi ako sa kasalubong ko at i respect them. sa amin, coming from Deparo Caloocan, going to Novaliches palabas ng Sauyo eh napakadilim ng mga kalsada, lalong hirap pa pag bumuhos ang malakas na ulan samahan mo pa ng foggy na windshield.
- 54,282
April 28th, 2017 10:52 AM #6i understand, po.
my concern is, the upgrade may be advantageous to the upgradee, but its glare might be detrimental to the oncoming motorist.
i am simply wishing, that upgrades should also include proper shielding against glare, even if it is the more expensive way to go.
my theory is,
with standard bulbs, stray light ("glare") is too weak that oncoming motorists are not bothered by this stray light.
but once the light source is upgraded, the stray light becomes much stronger, and is now going to affect the oncoming motorist. in this instance, reflectors should also be upgraded, to "tame" the light beam into a tighter direction.Last edited by dr. d; April 28th, 2017 at 10:56 AM.
- Dec 2016
- 208
April 28th, 2017 11:04 AM #7ang naiisip ko lang is, say i will upgrade my bulbs sa mas malakas na ilaw...siguro we just have to make sure na tama ang "tutok" ng ilaw at di nakakasilaw sa kasalubong na sasakyan. kung madami lang akong pera, sana nagprojector na ako..hahaha!
- 54,282
April 28th, 2017 11:08 AM #8i have been driving for over 25 years.
and one thing i have to keep telling myself. "if you have to use your lights, it means you should also drive more slowly".
those roadway speed limit reminders on the road, are meant for bright daylight or ideal driving conditions.Last edited by dr. d; April 28th, 2017 at 11:11 AM.
April 28th, 2017 11:15 AM #9
Do you have tint on your front glass? If so, maybe you may opt to remove or choose a lighter shade given thta you said you have a hard time driving at night?
- Dec 2016
- 208
April 28th, 2017 11:16 AM #10thanks so much sir *dr. d
may makakapagrecommend ba dito ng shop na pwede kong pagawan ng HL at fogs ko? yung masasabing "responsible" owner ako pag nagsindi ako ng ilaw ko at may nakasalubong sa kalsada? thanks!
The hybrid release was also basically an all-new model release for TMPI, I think.
2021 Toyota Land Cruiser LC300
