Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Jul 2010
    Have experience with my New MS GTV after 1000 km service was complete change oil with turbo xp and after 3000 km found very dark crankcase oil. I, wonder if this is normal for crdi engine?
    Aug 2004
    Oil naturally gets dirty over time. Especially on diesels. As long as the level doesn't start going down, it's okay.
    5000km ba yung service interval?
    Yeah that's true. Magtaka ka kung hindi umiitim. hehe
    5,000km nga recomended interval.
    Oct 2007
    A perfectly normal condition in every diesel engine. The oil washes the engine of contaminants, the filter then cleans them out.
    Jul 2010
    Thanks for reply mga sir, naintindihan ko mga reply niyo na umiitim talaga ang oil in the long run, pero sa 3500 sa observation ko sobra talaga. Ngayon may nabou akong conclusion dahil sa mga nabasa ko dito sa forum. Since inilabas ko ang unit ko after 1000km service nagtop up ako ng V-power diesel with the consent of my dealer and they said ok daw ang V-power diesel.
    kala ko normal lang na medyo mausok kasi di ko naman naobservahan maiigi noon, pero this few top up bumalik ako sa normal na diesel at di na mausok ang ride ko. kaya duda ako na and dahilan na umitim ng sobra ang oil ay sa diesel na naikarga ko.
    So now, I finally decide to renew my oil at 5000 km even the PMS is top up and new filter lang ang recommendation.
    Lesson learned: no more V-power in my MS
    Jun 2011
    Normal especially on diesel. And I think it has nothing to do w/ your gasoline. Actually, if you check the oil in the dip stick, yes it's black.. but if you drain it to some pan, you'll see it's not that dark after all. Same banana w/ our VGT.
    Jul 2010
    Quote Originally Posted by GodziRRa! View Post
    I hope ganun nga sir, na ok ung oil even so dark as per my observation, yes agree ako nothing to do with fuel especially with new engine. But as per experience trunk type and engine natin means pag old engine na may chance na macontaminate na ang crankcase oil. Thanks
    May 2008
    Quote Originally Posted by dancorps View Post
    I'm also using VPD no problems naman with my oil. Still relatively clean after 3K.
    just make sure din sir na talagang pinapalitan yung engine oil ng casa... read of a post here in tsikot, i think its also a montero sport hindi pinalitan ng casa yung fuel filter although sabi sa job order replaced daw.
    Jul 2010
    Quote Originally Posted by junerski View Post
    Sir, doubt nga ako kc pagcheck ko nung palabas pa lang sa kasa medu mix na ng new oil at old. Bukas punta na ko kasa at i will make sure na magawa lahat ng tama, tiwala kc ako nung una.
    Jul 2010
    Quote Originally Posted by Reepicheep View Post
    Sir how about the smoke thing issue is it normal? kc mula ng maubos ko na sa tank ung VPD na observe ko na very slight smoke na sa tail pipe ko. Imagine nu sir nung nka VPD pa ako, my wife wear white pants at naglagay lang ng groceries sa compartment at natapat sa tail pipe legs nia umitim kaagad pants nia, "he, he nakabawi kagad ako"... Note: the engine and aircondition already started 5 min. ago.
    Also VPD smoke smells irritating than normal diesel oil, please observe mga sir,s and share us your comments.
    Aug 2004
    V-Power by itself should not cause that effect. It is possible that there was a lot of carbon build-up that V-Power cleared away.
    Or... it's possible that the fuel at that particular station for that pump (separate tanks ang V-Power at Diesoline) was contaminated.
    Apr 2011
    Natural lang na mangitim yan at dun mo malalaman na nagwowork nga un oil.
    Pero baka naman nag top-up oil lang un casa mo sayo at hindi ka nila pinaltan talaga. since wala ka sa service area baka nag dagdag lang sila then ang billing statement mo ay complete change oil at ang tunay na napaltan ay un oil filter mo lang. Its just me sir ha.
    May 2010
    why not try Petron Turbo D? Well, engine oils especially on diesels are supposed to get dark even with just a kilometer of driving after oil change.
    Jul 2010
    At 3700km dinala ko sa service center at abnormal din daw ung pagkaitim ng oil say ng chief mechanic kaya gumawa ako ng report at observahan pa, I did complete change oil and oil filter, with mineral oil muna for cleansing, I will observe for this time, at sana everything will be alright kasi di na mausok unit ko not like before.Hung on mga sir...... thanks
    Use shell helix diesel, they do a good job cleaning the engine IMO.
    May 2004
    mas ok yata yung umiitim that means nakukuha nya mga dumi
    Aug 2004
    Well... the chief should know more about the MS, but in my experience, dark oil at 3000 is normal. Hell... my Crosswind's oil goes black the minute I start it. Other cars have it gradually darken over time.
    You should observe the oil every 500 kilometers and take notes.
    May 2011
    Wouldn't a darker oil be better since it means more dirt is being cleaned off your engine?
    Feb 2011
    pero napalitan naman daw ba yung oil mo nung change oil sir? para maka sigurado ka next time na magpa service ka sir eh bunutin mo dipstick mo after i release, bago ka umalis sa casa. pag clear, sure un na napalitan. kasi experience ko sa innova, kinukuha ko sa casa yung used oil ko when nagpapa service ako para maka sure ako na pinalitan din nila. pati nga oil filrter pinababalik ko sakin eh kahit di na yun magagamit para sure akong pinalitan. pag idle makina mo mausok? in my experience with my aunt's GLS monty, wala syang usok pagka idle, mismong pagka start lang umuusok. and constant naman yun diba. try mo kargahan ng caltex diesel. it is very good in the engine due to my experience with the innova and GLS monterosport. :D
MS GTV very dark oil at 3500km
