Results 1 to 3 of 3
    Oct 2009
    Hi,
    Can someone please tell me how to access the bulbs in the tailight of the mitsubishi pajero?
    I've removed a total of 5 screws, but cant pry it off.
    Thanks
    Open tailgate, loosen screws
    Pry it gently going outward towards the sides.
    The driver's side taillamp has an extra pin sometimes that needs to be removed. It holds the black plastic thing.
    The taillamp is clipped on to the body on its leading edge (behind the fake vents). A forceful push or slap in that area can loosen it.
    Sep 2009
    Quote Originally Posted by ginomonpon View Post
    Hi,
    Thanks
    you will just need to remove 2 screws to pry the tail lamp assembly, its located between the rear door locker if its on the driver side, then pull toward you tanggal na, look for the wired round object then click counter clockwise then pull out andun na ung bulb, hope ythis will help
How do you change the tailight bulbs of PAJERO 96 model
