Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Feb 2004
    guys, i know that it is probably in the manual, pero di ko mahanap manual ko
    can you guys help me decipher the positions on the 4x4 shifter of the pajero gen 2? what is on ths shifter again?
    2H, 4H, 4HL, 4L, 4LLc?
    tama ba yon? what do the 4HL and 4LLc mean? when do we use it?
    thanks,
    andy
    2H - Rear Drive
    4H - 4WD High - On road AWD. Use for greater traction on wet highways
    4HLc - 4WD High, Locked Center Differential - Use for driving in sandy surfaces and snow/ice.
    N - Neutral (transfercase in neutral)
    4LLc - 4 Low - Low gear, for demanding 4x4 situations like mud, climbing etc.
    Feb 2004
    pajerokid, thanks. when you say locked center diferential, does that mean that both left and rigt tires will turn regards less of what happens? hindi parang sa F150 ko na kung nakaangat ang isang gulong, it just keeps spinning and the other tire doesn't turn.
    andy
    Lucky Center Diff Lang....hindi yung rear diff mismo
    Don't get confused with locked center differential from your transfer case and differential locks from diff/axle ends.
    Locked center diff manipulates power transfer front to rear towards prop shaft only. While differential locks perform by locking the left and right tire during traction slippage.
    Lucky, tama sila. The center diff is there so that you can enjoy your 4WD onroad. Kung walang center diff or some similar device (conventional 4x4), you will encounter a condition called binding, wherein mahihirapan lumiko ang truck mo (among other symptoms). That's because roads are pretty 'makapit' and often do not provide enough slip for the tires to rotate for themselves (hence the need for a center diff).
    Instinct na sakin ang paggamit ng 4H kapag umuulan. Better traction nga.
    And meron akong theory (which of course could be false).... keeping your ride in 4H reduces brake locking. Diba, if you brake to the point of locking, kung gumagana ang 4WD, it will make the tires spin again.
    Logical but again, just a theory.
    Hehe! In any case, Oki talaga SS4!!!
    Can't have the best of both worlds in one rig, tough luck for some like ours who doesn't have SS4.
    anung SS4?.hehehehe
    Feb 2004
    okay, now i get it. so kailangan pa talaga ng manual differential locks/lockers ang pajero para and left and right side wil lock and walang gulong na magspin lang sa hangin
    andy
    SS4 = Super Select 4WD
    Jon, Oks lang yun! Pang heavy duty naman yung sa inyo e!
gen 2 pajero 4x4 shifter deciphering (help)
