Results 1 to 8 of 8
    ang tagal nya mag init ang engine...usually it takes 5 to 10 mins pa...pag dmo naman pina init nag pupugak pugak pag tumakbo? lancer el 94 model..1.3liters
    Aug 2004
    Busted na thermostat mo. Palitan mo na. Stuck open na siya.
    Jan 2008
    Quote Originally Posted by cArBoN View Post
    sir ano pa talaga problem mo?? matagal lang uminit engine sa umaga?? or yung pumupugak pugak pag itinakbo mo agad?? as far as i know.. hindi naman problem yung matagal uminit ang engine.. your problem is that pumupugak pugak sya pag itinakbo mo agad then pag uminit na eh ok na takbo smooth na ulit..tama po ba?? kung ganun po problem next question ko is EFI ba engine or Carb?? kung EFI kasi baka may mga sensors ka na hindi gumagana.. especially yung mga air mass sensors, exhaust and other electronics like spark plugs distributor assembly, also timing ng engine.. kung Carb naman you need to check yung electrical parts sa distributor assembly like yung distributor cap, rotor, condenser and contact point, check mo din timing.. kung OK na lahat and still ganun pa din problem na pmupugak pugak sa umaga at pag uminit na engine ay ok na, My diagnosis to your problem is that it has a high probability of STEAM build-up inside your engine.. The steam builds up when you turn off the engine and let it cool down just like when you got home at night and use it the next morning... So in the morning, when you start up the engine there is still STEAM/moisture in the combustion chamber that causes nag pupugak pugak, until the engine reaches its operating temperature, then that is the time that the STEAM/moisture already dissipated then the engine can run smoothly...
    possible you might need to change some gaskets in your engine to seal off this steam.. Its not actually water leaking inside your engine but rather "STEAM" only that condenses and forms moisture affecting the combustion process in the first start..I know this because we have a nissan vannette before CARB engine.. everytime you start it in the morning, Idling is ok but when you try to rev the engine or run the car immediately... the engine starts the pugak pugak problem as if the engine is drowning...
    hey sir YAPOY86...maybe u have answered my problem...are u professional auto mechanic? we need you buddy..pls..stay always on the line....thanks a lot...more advice mga bros...
    Jan 2010
    tanong ko lang sana sir kung ano ang nakasagot sa problem nyo. TIA!
    Apr 2010
    sir, ok lang bang gamitan ng gasoline with E10 ang gas carburator engine, may kailangan pa bang palitan. nung nauso na kasi ang E10 eh di na ako naglagay, nag shift na ako sa BLAZED eh sobra naman ang mahal, Dati naman gumagamit ako ng EXTRA. Kung gagamit ako ng E10 , wala bang epekto sa carburator ko, TNX
    Lance
    Oct 2008
    Yun pupugak pugak na engine. Madalas related sa Spark plug. Either busted na ito at kailangan palitan. Pwede rin sirang high tension cable or maruming contact ng distributor.
    Oct 2008
    ganyan din dati problem ko sa singkit ko carb yung akin pinalinis ko lang carborator ayus na kahit malamig panahon once na start ko smooth agad ang takbo
    Hope this help : )
Ano po Problem ng Car ko?
