Results 1 to 5 of 5
    Aug 2008
    [SIZE=3]Hi,[/SIZE]
    [SIZE=3] [/SIZE]
    [SIZE=3]I was wondering if some one could help me out regarding Pajero’s from Subic. There are a good no. of pajeros that have already been converted being sold in the market, I’m planning to get one. What should I check for when I shop around? I heard that the gearbox, transmit ion, dash board and side mirrors should be changed? Any thing else that I should be aware of?[/SIZE]
    [SIZE=3] [/SIZE]
    [SIZE=3]I really appreciate the help guys![/SIZE]
    [SIZE=3] [/SIZE]
    [SIZE=3]Thanks![/SIZE]
    you don't need to change gearbox, transmition, dash board and side mirrors.
    unless it's a raw LHD vehicle.
    you only need modify the side mirrors.
    parang lotto yang Subic rides.
    may suwerte, mint condition. may malas naman. bad engine condition.
    and usualy bumibigay yung alternator, reconditioned aircon,
    I quote this from our fellow tsikoteer.
    Simple lang advise ko sir: if you are a car fanatic, ok lang, especially if you're well informed DIY-guy or an experienced car enthusiast. Also good if you're a budding car enthusiast because this will definitely increase your experience in cars. Reason: You would know what to fix and replace.
    If you're just a regular driver ("gas and go" type) DO NOT. Reason: You wouldn't know what to fix and repair and when.
    if you decide to go for it, make sure you change the oil,fuel,atf,air filters. palinis mo na rin injectors and psi setting. injector cleaning costs 500 more or less lang. check the headlights aim too...
    Jun 2008
    you got pm!
    Quote Originally Posted by rion View Post
    oopps mali... kahit raw Japan pa yan. no need to change those things...
    Sep 2012
    Sir, tanong ko lang kung may alam kayo kung saan magpapakabit ng aircondition ng pajero para sa gitna tyaka sa likod, yung pang pajero talaga. kasi yung sa tito ko subic din pero meron na aircon sa gitna tyaka likod, samin wala pa.
subic pajero's
