Results 1 to 4 of 4
    Apr 2009
    Good day to all
    I would like to buy Mitsubishi Galant SS 7th Generation
    Need ko rin po ng mga information ng mga sumusnod:
    1. Pano ko po ba malalaman kung converted cya from right hand drive to left hand drive? kc pag imported daw po from japan ay puro right hand drive daw.. Totoo po ba? or hindi lahat?
    2. Pareho lang po ba ang Mitz Galant 7G na SS at VR4? or magkasama yan? or merong galant 7g na VR4 lang at SS lang?
    3. May 4 cylinder po ba na DOHC? or lahat po ng DOHC ay 6cylinder?
    4. Ano-ano po ba dapat kong i-check kung kukuha ako ng GALANT?
    5. Ilang Kilometer per liter po ba ang galant 7g VR4? City driving, and long drive?
    may nag bebenta po kc sakin
    Mits Galant SS 1998
    Automatic
    Maraming salamat po sa inyong lahat.....
    Sep 2009
    "hiwalay po ung SS at vr4 sir,mas malakas ang makina ng VR kesa sa SS as for the other questions di lang ako sure duon,pero ask for more replies sir.."
    Apr 2009
    *rex31angel
    sir Tnx po sa info... ganon pala yon... kaya meaning medyo mas malakas mag consume ng GAS ang VR kesa SS?
    Apr 2004
    lahat ng galant malakas sa gas... kahit yung mga pinaka luma na 93 model.
    if gas consumption is an issue to you, don't buy a galant.
    if it's not an issue, i suggest you go to port irene, meron dun binebenta VR4 (4 wheel drive!!) na may turbo pa. astig. kung may pera lang ako binili ko na ito. you can always replace the power steering assembly with local sourced galant parts if the conversion is not perfect for you. pati dashboard palitan mo pwede rin, kuha ka ng local na surplus.
Mga GURU Need INFO for Mitz Galant SS VR4 7th Gen.
