Results 1 to 8 of 8
- May 2010
- 104
March 11th, 2011 09:15 PM #1ayaw mag start ng engine ko
Here are the list ng ginawa ko
0.)Switch the ignition sounded "tick tick tick"
1.) I remove the battery and reattach it, and when i switch the ignition is just "tick"
2.) When i turn high beam on i notice the radio turns off like it lacks power
3.) I also notice my windshield wiper is slower
4.) the dashboard is showing Red Battery warning
ano kaya problema ? low battery lang kaya okay lang pa parecharge sa mga talyer? or dapat sa motolite?
Salamat in advance
__________________
Mitsubishi super salloon
- Jan 2011
- 44
March 11th, 2011 09:34 PM #3
Check mo tubig, baka kulang lang. OR palit battery na yan bro. Baka pag pinacharge mo yan at may puntahan ka eh di na yan magstart doon pag aalis ka na. Hehe.
- Jan 2011
- 44
March 11th, 2011 09:37 PM #4
- Jul 2008
- 292
March 11th, 2011 10:00 PM #5ipa-check mo po alternator baka hindi na kumakarga, tapos palitan mo na ng bago yung battery para wala ng sakit sa ulo.
- Sep 2007
- 64
March 11th, 2011 10:37 PM #6sir for sure battery yan pero ano kaya ang cause. kasi according to my mechanic hindi basta basta na dre-drain ang battery unless
1. degraded na yung battery (needs replacement)
2. alternator is not functioning well. ayaw na mag charge.
3. ayaw mag start ng sasakyan kaya multiple tries mo start yung sasakyan, madali ma drain battery pag ganyan and usually caused by a faulty starter.
sana po ma solve mo agad.
- Dec 2004
- 114
March 17th, 2011 11:48 AM #7IC on Alternator. Battery drained because of this, so battery is also a problem. If you're in Manila, in front of Petron Pedro Gil, there's a good shop there specifically for these cases. Forgot the name of the shop.
Hope this helps.
March 17th, 2011 07:48 PM #8
Sounds like an alternator problem. Try to jump start it..or push the car to have it start. then remove the negative on the battery and wait to see if the car dies. if the car dies..then it's the alternator.
I've had the same problem w/ my Nissan. I bought a refurbished alternator for 1kand the problem was fixed. with my experience, sometimes it's nice to have your alternator fixed than buying a surplus one.
How about 97 LXi?
Civic horsepower
