Results 1 to 10 of 39
- Dec 2005
- 4
January 22nd, 2006 01:14 AM #1Is it really true that the tire pressures for the adventure are 28 psi (front) and 50 psi (back) respectively?
January 22nd, 2006 01:32 AM #2
bro kita sa may gilid ng pinto ung suggested tire pressure. naka indicate don sa may sticker sa gilid.
- Oct 2005
- 317
January 23rd, 2006 09:42 AM #4
Originally Posted by fLaKeZ
unfortunately yes... mukhang yan ang nakalagay sa gilid ng pinto... pero para kc skin di ko sinunod... even nung stock pa tires ko.. masyado mababa sa front sobra taas nman sa rear.
January 23rd, 2006 08:53 PM #5
'Di ko rin sinusunod yung factory specs. Masyadong mababa yung front pressure, eh diesel pa naman yung makina ko.
30psi for the front and 36psi for the rear works best for me.
- Dec 2005
- 4
January 28th, 2006 04:24 AM #7
mine is GLS Sport 30psi front 35psi rear, pero ngayon 30 psi nalang lahat ng gulong mas oks!!!
January 28th, 2006 04:27 AM #8
Originally Posted by justin_1179
February 6th, 2006 09:56 PM #9
The recommended tire pressure posted in my ride (GLX 2005) at the driver side door is 26 psi front tire and 36 psi rear tire. some may comment that the front tire pressure my be too low. I believe MMC will recomend these tire pressure because they have tested it in every model that comes out.
The said tire pressure is gauge on cold condition. once you start to drive especially on hot weather, this pressure goes up + 2 to 3 psi.
I use the said tire pressure without any problem, smooth driving
February 6th, 2006 10:21 PM #10
me,i have a 2005 gls sport,also having a 26front and 36rear before........pero tinaasan ko dahil para mas mabilis... ginawa kong 33front at 38rear...mabilis nga...... naka 115km/h ako sa 3rd gear at 4500rpm....try mo if you want speed...... my ride is still young... only 1700km old pa lang.... dumedede pa nga eh....hehehehe
Last edited by ecnerwal; February 6th, 2006 at 10:54 PM. Reason: WRONG INPUT OF CHARACTER
VinFast VF 3
