Here's my car...
91 Mitsubishi Galant Super Saloon, GTI Look
Engine is 4g63
Newly overhauled, Balancer removed
Here's my problem...
When you start the car, it runs fine, once the engine gets hot, the oil pressure light turns on, blinking at times, when accelerating it turns off, when idle it turns on.
Recently fixed...
Oil Sender was replaced, no problem in electrical, oil level is normal, engine sound is ok and no other noise.
What's the problem then?
Engine Bearing? Noooo, overhaul na naman, bwiset na mekaniko yun ah
Balancer Shaft? Noooo, overhaul again
Oil Pump? Sana ito lang ang problema
