Results 1 to 10 of 5006
- Feb 2011
- 51
April 3rd, 2012 11:18 PM #1Sir thanks for the info... buksan ko ulit bukas hehehe! Sir do you know how to open or disassemble the dashboard hanggang sa may lighter? baka pwede mo ako turuan? hahaha! ung clip ng top part ng dashboard nasira ko na nga eh, ayoko na madagdagan. Nalaman ko lang ang tamang way to open it sa isang member dito (ikaw ba un sir?) na nag post sa youtube.
April 3rd, 2012 11:31 PM #2
sir si master zix yung nag post sa youtube on how to remove yung LCD cover. as for the disassembly ng center dashboard, medyo madami need baklasin sir, just need to be extra careful para hindi masira yung mga clips.
need first sir to remove yung lower dash cover sa driver side and the glove box pati na din yun cover sa likod, be careful on the airbag connector sir. after that, need to remove again the LCD cover kasi meron 2x screw sa tabi ng LCD mismo. then remove the 2x screw naman sa ilalim na portion ng center dash. after that remove din yun cover ng down light muna before removing yung cover kasama ng cigar lighter. after all these, remove the 2x cables sa likod/ilalim connecting the A/C vent and temp controls. you can then carefully pull-out the center dash sir...
- Feb 2011
- 51
April 3rd, 2012 11:42 PM #3
- Jan 2012
- 70
April 4th, 2012 10:05 AM #4i just had a problem with my HU ... when i plug my iphone and play movies it has a sound but there is no display"BLAcK lang ung color" on HU can someone helped me?
Tsikot Member Rank 1
- Jul 2009
- 4,090
April 4th, 2012 08:33 PM #5Sir okay na ba HU mo? Usually nagkakaganyan when from accesory tapos mag start ka ng engine, so nag rerestart din yung MIS, minsan ganyan din yung sakin, all working kaya lang blank screen. On off lang tapos okay na siya ulit. Kaya what i did naglagay ako ng capacitor, just enough na kahit mag start ka ng engine, hindi naiistorbo yung pinapanood mo or pinapakinggan mo na music
- Jan 2012
- 70
April 5th, 2012 09:46 AM #6
April 6th, 2012 12:16 PM #7
- Jul 2009
- 4,090
April 6th, 2012 02:11 PM #8
i was looking for a 10000Mf 16V capacitor from my "baol", but found a 10000Mf 50V, pwede din naman kaya lang if you are going to buy, mas mura yung 16V. anyway, just connect the wires (parallel), + to the battery supply on MIS, - to the ground of MIS, mas malapit sa MIS socket, mas maganda, para sigurado walang voltage drop on start-up ng engine.
Same design language across the range is fine Porsche, Audi, VW, Lexus and Mazda are all like...
China cars
