Page 142 of 239 FirstFirst ... 4292132138139140141142143144145146152192 ... LastLast
Results 1,411 to 1,420 of 2384
    Aug 2008
    #1411
    Quote Originally Posted by istan View Post
    Yes, equiped w/ INVECS III ang lahat ng matic ng Lancer. 1.6 or 2.0 models.
    Ok naman performance. Abuse this -> 100kph at 2000 RPM. yummy!
    My wife likes honda jazz, pero im convincing her na lancer is ok din at bigger pa, with much cheaper maintenance over honda. Isang tanong na lang po matipid ba fc ng lancer 1.6 this is what i'm considering to buy. Thanks sa replay bro.
    #1412
    Quote Originally Posted by Terrence View Post
    The Lancer cheaper to maintain than the Jazz. San naman napulot yan? If remember Honda allows their cars to be maintained every 10,000km while Mitsubishi requires you to do a PMS every 5,000km. Add the fact that Jazz is a subcompact requires less oil than a compact Lancer. All these Honda high maintenance costs is so baloney unless you still live in the 1990's. I was just checking my calendar 2009 na tayo unless I am in some kind of time space warp
    #1413
    Quote Originally Posted by rllopez1229 View Post
    guys, ask ko lang, kasi yung gt-a ko white e lam nyo naman po dito sa pinas, kurakot mga taga government kaya puro spalto lang nilalagay nila sa kalsada. Ask ko lang po, masama ba yung ginagawa ng carwash ko, binubugahan nya ng gas ung most part na may spalto ng gas.. Ok namn. Is it bad to the cars specially sa paint..
    Better use a commercially available tar remover, if you can find one. But I read somewhere before that as long as kerosene doesn't stay long on the paint, it is virtually harmless. HOWEVER... the kerosene, being a solvent, will take off some of whatever sealant/wax you put on the paint. So just be prepared to re-seal and/or re-wax. And of course, "as long as it doesn't stay long" is the key phrase... wash the kerosene off thoroughly right after applying it.
    #1414
    Of course Lancer drinks more oil than a Honda Jazz, Lancer 1.6 vs Jazz 1.3L/1.5L, hence compared to Jazz, it will be more expensive to maintain than Lancer (1.3L = +-P1.5k * 10k kms, 1.5L = +-P500 *10k kms). As what Tidus said.
    What you do is compare it with Altis or Civic. Although Civic is 1.8L.
    For my Lancer, although, recommended maintainance for Casa is every 5k kms, I skip that, and go every 10k kms. Why? Because what the Casa does at every 5k is just check everything if its working fine. Top up oil and other stuff. If the car has no problems at 5k, skip it. Less hassle for you and your pocket.
    Depends on what you like though, Jazz or Lancer. Pero masisikmura mo ba na Subcompact car at P712k - P810k compared to a compact car at P685k - 745k? Mas malaki space ng Lancer for 5 people w/ cargo kaysa Jazz. Lancer has better torque low down the RPM range due to CVT, while for Jazz, you'll have to rev the engine to get better response (as what car reviews said). For zipping the city, both cars are great though.
    In my personal opinion though, Lancer has better materials than Jazz. Too plastiky for my taste.
    #1415
    most neighborhood car washes use kerosene to remove road tar from body panels. it's cheap, readily available, and not harmful if done properly. they should rinse it off immediately lang. after that, re-wax the panels as the kerosene strips of whatever wax was present before.
    if you don't trust your car wash place, i suggest DIY na lang. commercial bug & tar removers can be had from your mall hardware store. if you don't want to do this, switch to a pro detail shop. search the board. there are lots to choose from.
    #1416
    guyz it's me again, my another concern ako bout sa ex gt-a, bkit gnun wala pang 1000 km reading may warning na periodic inspection?.. nagwworry na kasi ako eh. hehe.. and guyz dba ung gt-a walang autolock ng doors? pwede kaya ipaautolock yun? thanks nga pla sa inyong lahat. Im proud being a member here..
    i would not worry too much about it. it's supposed to tell you that your car is due for inspection. in my case, since i bring my car for PMS regularly, i just simply turned off the warning. read your car manual. search the net. i'm sure you will find your answers there.
    Apr 2009
    #1417
    right on dude! i agree with sir magister!
    to rllopez1229! READ your freaking car MANUAL dude!
    before hitting the keyboards!
    SURF dude SURF!
    #1418
    Quote Originally Posted by OUT-101 View Post
    SURF dude SURF!
    Natatawa ako sa "twak" icon (yung pukpok sa ulo). Hehe.
    Nov 2007
    #1419
    Sir Tidus tambay ka din pala dito, he he he matagal na ko di nakakapag post dito sa forum na ito
    Nov 2007
    #1420
    and ano or saan ba ung winterpine? Nakakainis pati, ung GT-A walang Back sensor. Importante kaya yun!!
    Sir mas ok kung reverse cam medyo magastos nga lang kasi pag sensor kakainis lang yung beep sound nya di accurate...naghahanap ako ng switch para sa central lock hirap maghanap
2008 Mitsubishi Lancer EX GLX / GLS / MX / GT / GTA [ARCHIVED]
