Guys need your advise on what brand/type and where can I purchase the following on a very reasonable price(s)
my ride is a 91 Pajero 3 door subic and I am planning on changing the following as a Christmas treat for my ride:
Headlight housing and reflector (sobra labo na kasi even with new Osram NBs)
Electronic side mirrors (sira na kasi ndi na gumagana dun sa switch sa console)
Shocks (recently matalbog na ang rear ko do I replace coilsprings? use gas adjust? ect.)
Airfilter (would you guys recommend if I use simota medyo budgeted kasi or stick to the stock disposable air filters? planning to set up a CAI sana to improve acceleration. would love K&N but baka wala na matira sa 13th month ko )
hindi na ba puwede mapalinis lang yang headlight housing mo?
ikot sa banawe lang katapat nyan. dami subic spare parts dyan. try mo hanap crystal clear headlights. baka myroon. though I haven't seen one myself for 3 doors.
CAI will barely improve performance basta diesel. a boost controller maxing it out * 12psi would be the best upgrade imo. sabay boost gauge to monitor boost level.
Sir Rion, ung housing pwede pa palinis yata, pero palitan na daw ung reflector.
thanks for the tip.
baka may mga ma suggest kayo na specific na brands dun sa mga ini inquire ko that will really help para alam ko hahanapin pag punta ko banawe and which shops have good prices.
have you done the washer mod? then knn mo na.. ok din yun alcohol injection.
change the headlight housing with the ones with LHD stamped on it.
crystal headlights that are found on gen 2.5 paj fieldmaster or change the round headlight housing to the crystal-type na makikita mo sa banawe..
may adjuster shocks mo, pwede palitan mo yan * 10Thou a set. or pa-refurbish mo muna kay cruven/zee for 2000+ per pc.. if you want, monroe yellow shocks ok din. tried kyb gas-a-justt medyo matagtag, good when full*lesser ang roll
