Results 1 to 9 of 9
    Aug 2003
    peeps, patulong naman. saang shop/areas ako makakahanap ng 70A 3-phase circuit breaker with common trip, preferrably GE ung brand? parang ang hirap kasi hanaping ung ganitong type. thanks!
    ano itsura? 3 pcs na breaker? recently lang nagpagawa ako sa koten mismo....maybe pwede ka rin pasadya sa kanila...
    Aug 2003
    sir, parang single phase po siya, pero 3 ung "segments" instead of two.
    sabi naman ng electrician e me mapagkukuhanan siya bukas. pero bibili na rin kami ng spares. our office has this annoying habit of burning through circuit breakers...
    May 2004
    try schneider phils. afaik dami nyan ah. we use merlin gerlin dati. medyo pricey lang sya.
    3Pole circuit breaker common term.
    mahirap nga lang hanapin ang GE brand kasi most stores sells SQD or Siemens.Bolt on or plug-on?
    you better check your circuitry bro.pag habitual tripping meron ng problema dyan.
    May 2004
    tama si vtec. pag mdalas tripping theres something wrong with the circuit. ayun schneider phils yata nagcacarry ng square D rito.
    Aug 2003
    bolt on po siya...which i think makes it even harder to find
    yah, talagang problematic ung unit namin. the problems started from one end of the room, and is steadily working its way towards the other end. talagang me problema ata sa pagkainstall. too many problems in too short a timespan imo
    mas mainam dyan bro kalasin nyo yong busted breaker then dalhin nyo sa mga electrical store/supplier.kung wala mang makitang GE atleast yong similar sa appearance.pag kasi bolt-on magkakaiba ang haba ng leg. pero kung may similar leg kahit di naman GE pwede ikabit.since 3pole yan , meaning motor ang load, either AC or whatever na electrcial equipment na pang 3phase.kaya dapat mapacheck nyo ng maige yong source ng problema dahil useless magpalit ng breaker till maayos yong problema.
    Delikado yan, malaman under rated ang ginawang wiring or the equipment load is just too heavy... baka magkasunog kayo niyan. Licensed electrical engineer ba tumirada ng wiring ninyo?
looking for 3-phase circuit breaker
