Results 1 to 10 of 93
August 25th, 2004 09:02 AM #1
Ang lalim dito sa Espaņa, buti nakaahon pa yung ride ko. May mga truck n jeep na tumirik. Ano ba talaga proper way na pag drive sa Baha on a stock car?
- 10,620
August 25th, 2004 09:08 AM #2water fording, siyempre no clutch, you wouldnt want a wet clutch pare.
August 25th, 2004 09:19 AM #3
panu pag matic?....
diba auto clutch un?.hehehe.. o mali ako?
i mean may clutch padin kahit na matic kasi un makina na..
o hinde lang gumagana utak ko.hahaLast edited by odell; August 25th, 2004 at 09:40 AM.
August 25th, 2004 09:22 AM #4Originally posted by kimpOy
paano ba? normal gas lang?
August 25th, 2004 09:26 AM #5
what i know is that dapat lagi kang nasa 1st gear and naka apak ka lagi sa gas. Baha experience? dami! Napasukan yung loob ng car ko, bantut! pinalinis namin agad.
August 25th, 2004 09:28 AM #6Originally posted by carlocaraddict
August 25th, 2004 09:32 AM #7Originally posted by dbulido
but if you can avoid it, put your car in 1st gear, turn off your aircon and go slow thru the water while avoiding the deeper portions of the road. Adjust your speed to be as fast as the bow wave in front of you (if the water is deep enough to create one).
August 25th, 2004 09:40 AM #8Originally posted by odell
panu pag matic?....
i mean may cltuch padin kht na matic kasi un makina na..
o hidne lang gumagana tuak ko.haha
So to try going thru a flooded road with an automatic:
-turn off aircon
-shift to the lowest gear
-proceed in a steady speed
-if you produced a bow-wave in front of you, go as fast/slow as the wave in front of you.
Always check your brakes after you leave the water.
August 25th, 2004 10:02 AM #9
my baha experience.
above knee high ang tubig, grabe lumusong ang kotse ko.
okay naman ang clutch at brakes pero after 2 days, alternator ko naggegenerate ng 19V~22V. Buti pinacheck ko kasi may batt umiilaw sa dashboard ko. kung hindi ko napacheck, luto ang ECU ko at putok sigurado ang mga bulbs ko.
August 25th, 2004 10:23 AM #10
Normal na dito yan sa Sampaloc area, kada ulan may mga areas na lubog talaga. Iwasan nyo ang Piy Margal (Instruccion-Blumentritt), Simon (Casanas-Blumentritt). Blumentritt, Calamba (Maceda-Isarog).
As much as possible try to avoid shifting gears while the vehicle is sumberged under water for manual trannys.
Matic trannys have lesser worries since, they don't have clutch openings underneath.Last edited by Ungas; August 25th, 2004 at 10:27 AM.
alas! no altis hybrids in the showrooms!
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
