call off the dogs, the hunt is over
[SIZE=2]This next example displays an issue that almost never arises but, when it does, there seems to be no end to the arguing.[/SIZE]
- [SIZE=2]Simplify[/SIZE][SIZE=3] 16 ÷ 2[8 – 3(4 – 2)] + 1[/SIZE][SIZE=2].[/SIZE]
- [SIZE=3]16 ÷ 2[8 – 3(4 – 2)] + 1[/SIZE]
[SIZE=3]= 16 ÷ 2[8 – 3(2)] + 1[/SIZE]
[SIZE=3]= 16 ÷ 2[8 – 6] + 1[/SIZE]
[SIZE=3]= 16 ÷ 2[2] + 1 [/SIZE][SIZE=3](**)[/SIZE][SIZE=3] = 16 ÷ 4 + 1[/SIZE]
[SIZE=3]= 4 + 1[/SIZE]
[SIZE=3]= [/SIZE][SIZE=3]5[/SIZE]
[SIZE=2]The confusing part in the above calculation is how "[/SIZE][SIZE=3]16[/SIZE][SIZE=2] divided by[/SIZE][SIZE=3] 2[2] + 1[/SIZE][SIZE=2]" (in the line marked with the double-star) becomes "[/SIZE][SIZE=3]16[/SIZE][SIZE=2] divided by[/SIZE][SIZE=3] 4 + 1[/SIZE][SIZE=2]", instead of "[/SIZE][SIZE=3]8[/SIZE][SIZE=2] times by [/SIZE][SIZE=3]2 + 1[/SIZE][SIZE=2]". That's because, even though multiplication and division are at the same level (so the left-to-right rule should apply), parentheses outrank division, so the first [/SIZE][SIZE=3]2[/SIZE][SIZE=2] goes with the [/SIZE][SIZE=3][2][/SIZE][SIZE=2], rather than with the "[/SIZE][SIZE=3]16[/SIZE][SIZE=2] divided by". That is, multiplication that is indicated by placement against parentheses (or brackets, etc) is "stronger" than "regular" multiplication. Typesetting the entire problem in a graphing calculator verifies this hierarchy:[/SIZE]
16/2(8-3(4-2))+1 = 5
16/2(8) = 1 (w/ parentheses)
16/2*8 = 64 (w/o parentheses)
[SIZE=2]Note that [/SIZE][SIZE=2]different software will process this differently[/SIZE][SIZE=2]; even different models of Texas Instruments graphing calculators will process this differently. In cases of ambiguity, be very careful of your parentheses, and make your meaning clear. The general consensus among math people is that "multiplication by juxtaposition" (that is, multiplying by just putting things next to each other, rather than using the "×" sign) indicates that the juxtaposed values must be multiplied together before processing other operations. But not all software is programmed this way, and sometimes teachers view things differently. If in doubt, ask![/SIZE]
reference:
http://www.purplemath.com/modules/orderops2.htm
now, tell me the answer is still 288!
