View Poll Results: My Answer to the equation is...
Voters
64. You may not vote on this poll
  • 2
    43 67.19%
  • 288
    20 31.25%
  • 42
    1 1.56%
  • no comprende senior!
    0 0%
Page 13 of 14 FirstFirst ... 391011121314 LastLast
Results 241 to 260 of 267
    #241
    Quote Originally Posted by jansky View Post
    hahaha..
    i conduct Survey sa mga sikat
    Justin Bieber
    President of the USA
    Jackson
    sagot nila 2 din nyahahahahah
    si jacko parang napilitan lang, si obama naman proud na proud.
    #242
    flying voter yang isa dyan eh.....patay na bumoto pa.
    masama pa yata ang loob ni jacko, kaya dapat dito kay jansky i-ban! and daming inaabalang tao. pero ok sir ginawa mo nakakapag-refresh ng utak.
    #243
    hahaha..
    Justin Bieber
    Jackson
    #244
    Si Mr. President lang naiiba sa kanila ah....
    :gayfight:
    May 2004
    #245
    Quote Originally Posted by vito corleone View Post
    mapuan. . .
    register na dito
    http://tsikot.yehey.com/forums/showt...=30907&page=21
    pasensya na kung ot
    *rene tagle, alam mo naman ang mga eng'g peeps, they know their math, but don't know how to put them in words so kailangan pang i-research. . .we all relearned something today :-)
    registered na ko dyan bro. barkada ko si Eddie Ngo at Eddie Molee kaya medyo nakakahawa math discussions.
    and you are very much correct re: engg peeps.
    #246
    hahaha.
    pag magpapa audit ka sa accountant mo at magbabayad ka sa BIR ang ibibigay nya 2
    pero pag magpapaudit ka sa accountant ng BIR ang ibibigay nya 288
    In the end, 42 na lang babayaran mo FOR THE BOYS
    May 2004
    #247
    Quote Originally Posted by phezthie View Post
    OT: about OT(old testament)
    naalala ko tuloy nung nasa MIT pa ako, pag alam na ang sagot because meron tip o OT of previous exams, write the answer first at the bottom of your exam paper then compute it pabalik
    basta i highlight lang yung answer by means of box, circle o double underline, di na mapapansin na mali pala yung computation ginawa hehehe
    well, we cant do anything dun. kaya nga mas mataas ang score ng magandang computation eh kahit mali pa final answer mo.
    naalala ko tuloy yung exam sa electromag, lagi ko check yung problem interpretation ng katabi kong magaling kasi dun ako mahina. pag pareho kami ng equation e di na uli ako titingin. nagulat na lang sya one time ako highest sa exam hehehe. tama final answer ko pero sila mali. pero same ang initial equation namin. ibig sabihin tama ko compute. nagkamali yata sila.:D
    #248
    288 sabi ni Hitler.
    [ame="http://www.youtube.com/watch?v=bwpWw-iVKHc"]YouTube - 48÷2(9+3) - Hitler parody[/ame]
    Mar 2007
    #249
    Natapos din... or tapos na nga ba??
    #250
    Langy*,- pati si Hitler,- nakigulo na rin dito.....
    Teka,- Math expert ba siya?....
    12.8K:toma:
    #251
    no need to argue bro..i may not explained it better.. it's just that i can still recall high school algebra..
    we're just discussing the right solution to that sample algebraic expression..
    #252
    call off the dogs, the hunt is over
    [SIZE=2]This next example displays an issue that almost never arises but, when it does, there seems to be no end to the arguing.[/SIZE]
    • [SIZE=2]Simplify[/SIZE][SIZE=3] 16 ÷ 2[8 – 3(4 – 2)] + 1[/SIZE][SIZE=2].[/SIZE]
      • [SIZE=3]16 ÷ 2[8 – 3(4 – 2)] + 1[/SIZE]
        [SIZE=3]= 16 ÷ 2[8 – 3(2)] + 1[/SIZE]
        [SIZE=3]= 16 ÷ 2[8 – 6] + 1[/SIZE]
        [SIZE=3]= 16 ÷ 2[2] + 1 [/SIZE][SIZE=3](**)[/SIZE][SIZE=3] = 16 ÷ 4 + 1[/SIZE]
        [SIZE=3]= 4 + 1[/SIZE]
        [SIZE=3]= [/SIZE][SIZE=3]5[/SIZE]
    [SIZE=2]The confusing part in the above calculation is how "[/SIZE][SIZE=3]16[/SIZE][SIZE=2] divided by[/SIZE][SIZE=3] 2[2] + 1[/SIZE][SIZE=2]" (in the line marked with the double-star) becomes "[/SIZE][SIZE=3]16[/SIZE][SIZE=2] divided by[/SIZE][SIZE=3] 4 + 1[/SIZE][SIZE=2]", instead of "[/SIZE][SIZE=3]8[/SIZE][SIZE=2] times by [/SIZE][SIZE=3]2 + 1[/SIZE][SIZE=2]". That's because, even though multiplication and division are at the same level (so the left-to-right rule should apply), parentheses outrank division, so the first [/SIZE][SIZE=3]2[/SIZE][SIZE=2] goes with the [/SIZE][SIZE=3][2][/SIZE][SIZE=2], rather than with the "[/SIZE][SIZE=3]16[/SIZE][SIZE=2] divided by". That is, multiplication that is indicated by placement against parentheses (or brackets, etc) is "stronger" than "regular" multiplication. Typesetting the entire problem in a graphing calculator verifies this hierarchy:[/SIZE]
    16/2(8-3(4-2))+1 = 5
    16/2(8) = 1 (w/ parentheses)
    16/2*8 = 64 (w/o parentheses)
    [SIZE=2]Note that [/SIZE][SIZE=2]different software will process this differently[/SIZE][SIZE=2]; even different models of Texas Instruments graphing calculators will process this differently. In cases of ambiguity, be very careful of your parentheses, and make your meaning clear. The general consensus among math people is that "multiplication by juxtaposition" (that is, multiplying by just putting things next to each other, rather than using the "×" sign) indicates that the juxtaposed values must be multiplied together before processing other operations. But not all software is programmed this way, and sometimes teachers view things differently. If in doubt, ask![/SIZE]
    reference: http://www.purplemath.com/modules/orderops2.htm
    now, tell me the answer is still 288!
    I changed my answer to 2 bago ko pa nabasa ito... Tinanong ko kasi asawa ko ang sagot niya 2 tapos nung sinabi ko na dapat 288 sabi sa akin sino ba sa atin ang magaling sa math? Yun tapos na.. 2 na sagot ko.
    #253
    pages going to 16 and yet wala pa tayo naririnig kay OB.. interesado ako sa magiging sagot nya
    The opposite of OB's answer is the correct one.
    Joke lang ha, OB. I like the Jimny too.
    #254
    Quote Originally Posted by Bin Diesel View Post
    LOL! :bottom::hysterical:
    #255
    "Understanding" ka pala Bro.Bin Diesel....
    12.8K:toma:
    #256
    wahahahaha pinakatamang dahilan para sa kasagutan!
    #257
    'langya, tapos agad ang usapan. . .samantalang dito sa tsikot, umabot pa ng 16 pages . . .eng'g ka, bro, tapos mas magaling pa ang asawa mo sa math?
    Nov 2007
    #258
    kaw naman.. Asawa yun eh.. papalag pa ba
    #259
    sigurado me kapalit na favor yun
    ot na. . .
    May 2004
    #260
    baka schoolmate/classmate nya asawa nya. tapos member pa ng HSM.
Math: right answer
