48÷2(9+3)=
Distribute 2 to 9+3
18+6
=24
48÷24=2
Lintik napa-isip pa ako. :hysterical:
48÷2(9+3)=
Distribute 2 to 9+3
18+6
=24
48÷24=2
Do things in parentheses first.
48 ÷ 2 x (9 + 3)
48 ÷ 2 x 12
Go left to right.
48 ÷ 2 x 12
24 x 12
288
http://www.mathsisfun.com/operation-order-pemdas.html
Do things in Parentheses First. Example:
6 × (5 + 3) = 6 × 8 = 48
6 × (5 + 3) = 30 + 3 = 33 (wrong)
Exponents (Powers, Roots) before Multiply, Divide, Add or Subtract. Example:
5 × 22 = 5 × 4 = 20
5 × 22 = 102 = 100 (wrong)
Multiply or Divide before you Add or Subtract. Example:
2 + 5 × 3 = 2 + 15 = 17
2 + 5 × 3 = 7 × 3 = 21 (wrong)
Otherwise just go left to right. Example:
30 ÷ 5 × 3 = 6 × 3 = 18
30 ÷ 5 × 3 = 30 ÷ 15 = 2 (wrong)
"Distributive property of multiplication. Early Algebra.
The distributive property of multiplication CLEARLY states that the 2(9+3) is an entire term and CANNOT be broken up. 2(9+3) follows the distributive property which can be rewritten as (2*9+2*3). Let me repeat the 2 outside of the parenthesis follows the distributive property of multiplication and must be factored and simplified before performing any other operations on it.
So this can be rewritten as:
48 / (2*9 + 2*3)
Which leaves us with
48 / 24 = 2
Answer = 2."
got this from the net, it seems that a lot of people are also arguing what is the correct answer.
I created a simple script to see what the result is.
copy-paste into a text file, name it test.html.
Then, open the file with a browser.
<html>
<body>
<script>
document.write("48/2(9+3) = " + 48/2*(9+3));
</script>
</body>
</html>
48÷2(9+3) is simply 48÷2×(9+3)
The rule in algebra is that operations follow the MDAS rule from left to right, with the parenthesis changing the precedence order. So, 48÷2 gets operated on first. The result is then multiplied to the result of (9+3) since the parenthesis around 9 and 3 indicate the summation must be done first.
This is just like
a÷bc
the above is NOT a÷(bc), because multiplication and division have the same precedence.
a÷bc is just (a÷b)c
You could check Google:
http://www.google.com.ph/search?q=48...ient=firefox-a
I respectfully disagree. The full term is The Distributive Property of Multiplication OVER Addition; it never says OVER DIVISION because in PEMDAS, multiplication and division are equal and evaluated left to right in the absence of parenthesis.
Distributive Property of Multiplication OVER Addition applies when you have something like
a+b(c+d) which equates to a+bc+bd because b(c+d) has precedence over a+b.
However, in the expression
a/b(c+d)
you cannot evaluate b(c+d) before a/b because multiplication has the same precedence as division, you need to follow left to right evaluation. So that expression becomes (a/b)*(c+d)
Parenthesis, Exponents, (Multiplication-Division), (Addition-Subtraction).
In the expression 48÷2(9+3), this is simply another way of saying saying 48÷2×(9+3), and thus your terms as 48, 2, and (9+3). PEMDAS then states that you evaluate the terms inside the parenthesis first, 9+3=12
Then, you are left with 3 terms, 48, 2, 12. Using PEMDAS again, since the remaining operators are multiplication and division, you just evaluate left to right.
Sabi ng calculator, 2 !
Wala nang away kasi ang sagot, 2 !
Alangan mo naman magkamali ang calculator diba.
Because the way you press the numbers on the calculator does not follow the PEMDAS rule. You must have first done
9+3
which is correct, because terms inside the parenthesis are evaluated first. However, you must have multiplied that by 2 immediately to get 24. You then Used 24 as a divisor for 48.
But that is wrong, because you performed the multiplication operation first, when it is the division that should have been done first as it is to the left of the multiplication operation.
I respectfully disagree. There is a reason why PEMDAS is followed by the different programming languages: to remove ambiguities in mathematical expressions.
The expression presented by the TS will evaluate to 288 in the various programming languages.
I have personally tried in Javascript, PHP, C#, Excel, VBScript, and Ruby.
im sorry pero nakakatawa na ang thread na ito hahahaha!!!
sagot ko is 288 -- (9+3 then 48/2 then 24*12)
pero napapaisip din ako parang pwedeng sagot din yun 2 eh.
UPDATE
tinanong ko pinsan ko na na nag aaral pa sa HS "2" daw sagot ( 9+3 then 2*12 then 48/24) hahaha!!!!
masakit na ulo ko dito hahaha!!!
Isn't the value " 2 " supposed to be the one being distributed to the sum of the values inside ?
I mean, the 2 isn't supposed to be a denominator.
The computed value after the division sign should be the one divided to the value " 48 "
I hope you get me.
Plus, the 2 and the parenthesis isn't being separated by any operational signs(?) that's why you should distribute it after computing for the sum of 9 + 3 ...
To get me further ...
