Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Oct 2015
    If you have gaps - would you (or have you already...) go for braces, or crown? Or just can't be bothered by it?
    Same with staining, did you go for bleaching, veneers, or something else?
    If the gap is bad, definitely. But braces is kinda off na if a person is older than mid 20s. It should have been done nung teens pa lang. I had braces before but I didn't have a gap. Honestly I just wanted color on my mouth
    I had my teeth bleached in 2005 ata. I drank iced tead everyday kasi and it made my teeth yellow. There's maintenance though and it hurts a little (makes your teeth ngilo)
    BTW isa sa una ko tinitignan sa tao ngipin hehe
    Jan 2014
    Haha. One time ginawa ko na tingnan sa ngipin yung officemate ko, i think napansin nya na yung mata ko nakatingin sa ngipin nya. Parang nahiya ako at sya naman parang sumimangot. Hahahaha.
    Oct 2015
    Paano pala yan Cathy, kung may nanliligaw sayo at type mo pero with crooked teeth, stained or pustiso? Semplang na?
    Jan 2003
    Teeth gaps have their pros & cons. Pros is hindi madaling mag cavity cause their apart and brush bristle can get in between teeth. The con is on the cosmetic. Pag adult na, jacket is the option.
    Quote Originally Posted by draiman View Post
    crooked and stained, if it's not that bad okay lang.
    Quote Originally Posted by macsd View Post
    May mga kilala ako na maganda yung size at color ng upper and lower teeth pero lahat may gaps. It has a large impact on the attractiveness of a person Sabi nga ng friend ko "one seat apart" daw ngipin niya :bwahaha:
    Hinde pwedeng maging type kung bagsak na agad sa unang qualification.
    Ano ba hitsura ngipin niya? Hehe
    This is one thing I'm most afraid of. Having a tooth pulled. Good thing my mom really took care and religiously brought me to dentists since grade school. Never had any tooth pulled, no jacket etc. I can't imagine how painful it is to have a tooth pulled. Yikes!
    Ako meron isa Hindi kasi ako masipag bumalik sa dentist nung naka braces ako kaya nasira ngipin ko. Pero dapat pala hindi binunot ng old dentist ko Buti na lang sa may molar kaya hindi kita. Hindi naman masakit magpa extract. Mas masakit pa nga yung filling.
    Maganda nga may gap palaging malinis ang pagitan
    As long as malinis ang tao okay lang kahit sungki pa. Pantay nga puro tinga naman at may amoy
    Depende nga, meron ideal i crown or meron i brace. Problema sa mga ganyan yung kinakapitan ang sisirain naman.
    Dentist ate ko and swerte nung natapos siya, siya na nagtuloy ng alaga.... Nung maliit kami dun kami sa lola kong dentist na ancient ang gamit, tuwing summer sched namin sa kanya, nagpapahuli kaming 3 magkakapatid paakyat sa hagdan dahil sigurado kung sino una, siya uuna uupo
    Oct 2015
    Minsan hindi tinga, pagkagat sa puto akala mo may keso ang puto dahil may naiwang dilaw,
    Oct 2015
    Sent from my GT-N7100 using Tapatalk[/QUOTE]
    Ako din!
    Oct 2015
    Quote Originally Posted by mesami View Post
    Ako din![/QUOTE]
    Quote ko si mam Cathy, Ako din! Araw Araw dyan ako nakatingin.
    Oct 2015
    Sa gaps , depende yan , yung iba di yan papaayos , Baka mawala identity.. Tignan nyo ni Madonna.
    tingnan mo si mengele!
    identified by his gaps..
    Sa mga Japanese, swerte raw ang sungki ang ngipin... 😉
    Gets ninyo??? :naughty2:
    "I've been
    To the
    Dentist a
    Thousand times
    So I
    Know the
    Drill.....".... 😁
    Sent from my Nexus 7 using Tapatalk
    Oct 2015
    Ang pangit yung malalaki na nga yung ipin may gap pa. Miron naman kasi na sadyang maliit ang ipin kaya nagkaka gap.. miron naman taong naka ngiti pero di kita ang gap kaya tingin ko e hindi na nood kaylangan ang pag papaayos.
    Sep 2013
    Kahit maganda ngipin kung amoy [emoji90] hininga wala din pinagiba, turn off pa din....
    Like ko sa girl yung pa butterfly ngipin sa harap, nakakaattract lalo na pag nag smile, basta wag lang amoy [emoji90]or amoy yosi
    Quote Originally Posted by NiCe2KnowU View Post
    Ganyan sa boss ko. It makes him look boyish. Cute nga.
    Pero pag malala ang sungki mas prone sa bad breath kasi dirt has the tendency to get trapped plus mas mabilis ata mabulok.
What would you do? Dental question.
