Results 1 to 7 of 7
    Apr 2009
    Can anyone recommend a good mini fire extinguisher na below 1k lang? I saw his flamebeater in lazada nasa 500 lang. Ok kaya yun?
    Mar 2004
    Kiddie fire extinguishers ... don't go cheap on these things ... cheap ones might not work well when you really need them to ...
    Dec 2013
    Quote Originally Posted by bail View Post
    Check youtube. There are several videos and you can judge for yourself. Good enough for small fires imho. But 400ml can only go so far...
    Sent from my LG-D855 using Tapatalk
    Even the 10 lbs extinguishers will give you only a few seconds worth of spray. For the car the smaller ones will probably do, but for home use 20 lbs is more suitable. Or several 10 lbs extinguishers.
    At home we have 1 Halotron, 1 C02, 1 dry chem and 1 AFFF extinguisher.
    Oct 2009
    may nabili dati ako sa kapitbahay ko na nag tatarabaho sa refilling shop ng fire ixtinguisher.maliit lang siya..pero 3 years na.sabi kasi na e expired daw ung laman nun.gagana pa kaya un..sabi kasi 1 year lang daw ung validitation nung mga ganun at kailangan daw ulit pa kargahan after 1 year.
    May 2011
    Ang apoy hindi nagtitipid. Pag binigyan ng pagkakataon lumalaki. Ingat lang sa mga flammables at combustibles. Pag aralan ang material compatibility
    Jun 2012
    Quote Originally Posted by jaypee10 View Post
    Yearly ang refill ng fire extinguisher. So 3 years, matigas na loob nyan
    Sent from my SM-A9000 using Tapatalk
Mini fire extinguisher for home and car?
