Page 62 of 142 FirstFirst ... 125258596061626364656672112 ... LastLast
Results 611 to 620 of 1411
    Oct 2015
    #611
    Mas solid ang papa tungan ng tiles at flat mas matibay siya. Ok din kubg adhesive para mas maganda ang kapit.
    Jan 2012
    #612
    Tiles have to lay flat or they'll be prone to cracking. A simple test after tile installation is to tap on each tile with an umbrella. If there is a hollow sound, the tile will crack sooner or later and should be repaired before turnover. Ceramic tiles need adhesive as theyre too light.
    #613
    Dapat naka hold 10% from the contract price for back jobs hanggang maayos lahat bago release yun full payment.
    yES tama eto ang dapat but kung susumahin mas malaki pa sa 10%
    Feb 2009
    #614
    Quote Originally Posted by newtocar View Post
    Tile adhesive ginagamit yan sa dry surface, dapat sa pag buhos pa lang ng flooring nasa proper level na, d mo na kailangan ng cement and sand para sa leveling mortar mo, doble gastos ka lang. Saka pag manipis ang mortar mo may tendency ito na hindi kumapit sa base concrete, mabibiyak lang yan at kakapak, ideal na concrete topping at least 1-2" na mortar with class A mixture.
    Ideally, the substrate should relatively be flat enough. That's why you use the thin set mortar(that's what it is called) using a notched trowel ( usually 1/4-3/8) of an inch to give the leveling effect of the fluid mortar until it cures. It also allows workability to make adjustments during the fluid state of the mortar. How you do yours is your choice.
    Apr 2015
    #615
    Ung mortar na sinasabi jan ay ung tile adhesive na mismo (kung tile adhesive ang gamit mo) na nilalatag sa concrete base o substrate. Habang basa nilalatag na rin ang tile para ma iadjust mo ung level at squareness nya. Kaya nga sa pag buhos pa lang dapat nasa tamang level na ung flooring mo. Kung hindi, mag concrete toping ka, which is kailangan mo ng cement at sand material na madadagdag sa budget mo.
    Jan 2016
    #616
    salamat po sa mga inputs nyo sa BOM.. i'll check it to our contractor.
    bale ang contract po kc namin is fix per square meter. sila na bahala sa lahat from start, materials, labor, up to finishing. So ang main concern ko po is kung tama ung mga sizes at dimension na nakaspecifiy sa BOM kaya malaking tulong po yung mga inputs nyo para mai-clarify ko habang maaga at mapapalitan kung sub-standard. May nabasa rin kc ako sa ibang thread about naman sa asphalt shingles roofing na dapat 3/4" daw ang thickness ng marine plywood and when I checked my BOM, 1/2" lang ang nakalagay so I will clarify it also.
    kung meron pa po kayo additional inputs sa BOM it will help me a lot.
    TIA
    Apr 2015
    #617
    ^ ung 3"dia na pvc pipe sa storm drain system, kung sa downspout gagamitin okay lang yan, pero kung gagamitin na linya as area drain/ catch basin to catch basin, maliit yan baka hindi tumagal ma clog agad, ideal at least 6" dia kahit ung PE pipe lang.
    At pag ganyan ang usapan nyo sa kontrata, siguraduhin mo na di ka titipirin sa materyales ng conttractor mo.
    Jan 2016
    #618
    kapag asphalt shingles po ba ang roofing pwedeng wala ng gutter?
    Mar 2015
    #619
    Everthing boils down to how good and meticulous the person who is doing the actual job and the quality of materials. There are a lot of inferior/fake materials nowadays. Just visit everyday.
    #620
    I think this is the most updated Thread (re posting here)
    This is my problem now, I decided to build my retirement house masakit sa ulo sa pag pili pa lang ng contractor medyo mahirap mag decide at ayoko magkamali sa pipiliin ko, here are some of my questions
    is 19k to 20K/sqm reasonable price elegant finish
    Who should pay for Vat i got a proposal from one of the contractor and I don't know what to reply yet since Im not sure if the VAT should be shoulder by me or by Contractor? (please help its very important matter right now can't find it on the web)
House Constuction [Merged]
