Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    bigla na lang hindi na formated. maayos pa kaya to? badtrip. ang matindi pa don. 40 gb siya na punong puno ng mp3. as in lahat mp3 laman. mga 300mb lang ung free. badtrip talaga.
    What brand?? try mo sa site ng HD mo baka may tool sila to save it.. if Seagate ang alam ko meron it happened to me na save ko naman lahat ng data ko.. but dami na bad sectors after that.. so after recovering my dates I changed the HD nalang
    seagate siya. sana nga ma recover pa. ano? i format ko na siya? kasi pag click ko siya hindi daw formated e. so quick format pipiliin ko para hindi mapatungan ung data....
    Get some help sa seagate website.. sayang mga MP3 mo hirap mag hanap ulit nyan
    pre na check ko na ung site ng seagate. hindi daw sila nag peperform ng data recovery... ano ung ginamit mong tool? hanapin ko na lang siguro sa mga p2p. syang nga ung mga mp3 e. badtrip talaga. todo dl nanaman.
    may nakakaalam ba dito ng authorize distributor ng seagate. kasi sabi sa site ng seagate under warranty pa daw. sa authorized dealer daw dalin e.
    salamat
    try mo seatools, ito yung tool na
    ginagamit ng seagate to recover data.
    try mo muna before formatting.
    good luck!
    Jun 2004
    if you format....all will be gone!
    maybe a firmware upgrade is all it needs!
    *try attaching the HD to an external box. and find it in my computer.
    *try attaching the HD as a slave to another PC with a different OS. (if it is not recognized now on a certain OS...try it on another OS, an older one. say Win2000 or Win98)
    the point here is: baka the drive was formatted previously on FAT32. and the current OS only recognizes NTFS or vice versa.
    just my 2 plastic centavos...
    tama baka iba lang yung file system type nung hard disk kaya sinasabi nya hindi formatted. baka na format yan using NTFS. you need to slave the disk into a Windows 2000 box. don't format it yet sayang MP3's mo.
    same file system siya, ntfs. nagtataka nga ako bigla na lang nagloko. kasi nag troubleshoot lang ako ng writer tapos bigla ng ganong. tinanggal ko lang lahat ng connection don sa hd, ide saka power supply. tinesting ko na rin sa ibang os. same result.
    may nakita na kong software ng pang recover ng data. stellar phoenix. kahit sinasabing hindi nakaformat ung hd e nakita naman niya ung mga dating nakalagay. hindi ko pa nga lang na rerecover kasi wala akong paglalagyan nung mp3. hindi pwede don sa same hd kasi baka mapatungan. hehehe. kelangan ko pa ng bagong hd. tinago ko muna ung hd para sigurado.
    salamat.
    Oct 2003
    Yes..thats the right decision. Get a new backup HD then try to install windows OS on it, then try to retrieve your data files from your mp3 HD using Windows client or in DOS mode. Then you can save it to the new HD, then format the old
    HD. You should have wrote a cd backup for each of your mp3 files for backup purposes. Also, try to have atleast 2 to 3 HD with Windows OS installed on all HD so you can swap it vis-a-vis when something goes wrong with the operating HD.
    Remember..."An ounce of prevention is worth a pound of cure".
    I hope this helps......
    May 2004
    Dapat meron ka din backup sa cd. sayang talaga kung mawawala yang MP3 mo.
    oo nga e. sayang talaga. gusto ko sanang i backup kaso magkano din ung mga cd. ilan din un. badtrip talaga. sa susunod mag babackup na ako ng paunti unti. para hindi sabay sabay. kahit papano hindi mabigat sa bulsa. kelangan ko ngayon mag-ipon para sa bagong hd.
    at hindi lang ako ang nakikinabangan don sa mga mp3 na un. pati mga tropa ko sa akin din nakuha ng mga albums. kasi hirap hanapin nung mga mp3 na un. wala dito non lahat sa atin. sayang talaga. kelangan ko siyang marecover.
    salamat
    Aug 2003
    hmmm...me ginalaw ka ba sa BIOS settings, particularly dun the addressing mode ng HD(e.g. LBA, Normal)?
    a bit too late but here's a good idea to store lots of files.
    External CD/DVD/HDD case with USB 2.0
    I have one for my PC at home and have a 15 gig HDD in it. Basically all the stuff I download from KAZAA like MP3, video and similiar gets dumped into it. Kinda helps to stop filling up my computer's HDD. And I can transfer it to another PC simply by connecting it via USB.
    mga sirs,
    mas cost effective pa rin po magbackup sa CDR, pwede na yung mga 9php each sa CDR-King dahil pang-backup lang naman..
    a 40GB harddisk needs the following:
    58 blank disc (700MB each) = 515php cost and a total of 4.5 hours to burn hehe
    a brandnew 40GB harddisk is around 3000php pero mas valuable pa rin ang datafiles kahit piso lang bili mo sa harddisk hehe
    ...or gamitan ng DVD burner, mas matipid..
    Dec 2003
    40GB hardisk
    dapat pinartition mo para kahit na masira yuung drive or nagkaprob ka bigla nakahiwalay yung files mo from your OS...
    pwede mo naman ipartition yun into 3HD or kahit ilan mo gusto....
    sa 40GB na HD ko ngayon, nakapartition siya sa 3. C:8GB D: 15GB E: 17GB
    yung drive C: maliit lang kasi yung files ko nakahiwalay...
    Pwede mo pa naman yan irecover eh... all you have to do is ilagay mo as slave yung HD mo na nasira, sa ibang PC.. tapos gamitan mo siya ng GETDATABACK na software... kelangan alam mo kung NTFS or FAT32 yung HD mo na nasira... kasi 2versions yung lumabas ng getdataback isa para sa NTFS at isa para sa FAT32...
    if you need a copy of that software i could send you one... just PM me your email add..
    Hope this could help you!.... :D
    *badkuk, wala akong ginalaw sa bios. pero may tinroubleshoot din akong isang hd, nilagay ko ung isa dito kasi may problema. ayaw pumasok ng windows nung pc ko nung nilagay ko. hindi kaya ung hd na nilagay ko ung dahilan. pero tinanggal ko na rin naman siya. nung tinanggal ko pumasok na sa windows. pero nagkaroon na nga ng error at un ayaw pumasok don sa isa. hindi raw naka format. ilang beses ko na tong ginagawa ngayon ko lang naranasan. badtrip.
    *ghost, mahal ng external e. saka ang liit pa. sayang talaga. balak ko na kasing mag backup non kasi kinakapos na ko, kaso tinamad ako sa dami. badtrip dapat talaga ng backup na ko.
    *rev, hindi ko na compute yon ah. hehe. nasa 500 lang pala. gusto ko din kasi easy access para kung may magpapaburn sa akin madaling hanapin.
    *mugen. yup nag papartition ako. ung isa kong hd na 80gig nakapartition siya. one for my os, documents, mp3s and other files. tapos tong 40 gig pure lang na mp3s. i'll pm you.
    dapat talaga nag backup ako.
    salamat sa mga reply.
    Jul 2003
    sir flakez, actually pag ganyan nangyari may lusot kapa, why not start your pc in dos mode, tapos idirectory mo lahat, tapos save mo isa isa hehehe yun nga lang d ata gumagana ang cdr nyan so its either sa diskette mo sya ilagay or sa mga flash cards... or kaya zip disk??? not sure though ginawa lang kasi yan before sa laptop nakita ko eh..
    btw, CD ngayon may P4 na or P5... and ok naman sila, wala nga lang warranty sa mga cdrking, i bought 50pcs last week walang prob lahat, and nababasa lahat ng mga cdr.. its a good way to back up your files
    oo nga noh. baka pwede siya sa dos. pero wala akong paglilipatan. hehe. kaya hintay muna ako bagong hd. hehe. iningatan ko na nga ung hd e. nilagay ko sa box ng seagate. may nakuha kasi ako dati. hiningi ko para pang travel.
    OT: ok ba ung 5 pesos na cdr? kasi parang nakaktakot. madaling matuklap ung pinaka film ata nun e. para kasing pintura lang na mumurahin ung nasa ibabaw. hehe. cge tingnan ko. ginagawa ko kasi bago ako bumili scratch ko muna ng key o kaya kahit anong matulis na bagay ung ibabaw ng cdr para kung madaling matuklap e sablay siya. un sa tropa ko kasing isang cd nahulog sa sahig tapos biglang nasipa, un, tuklap kagad. mukhang mas nakakatakot. hehe. ok na ung 9 na ridata.
    salamat
    Yung HDD size depends on you. For me, I had a 15Gig HDD laying around so I used that one. So the real cost is buying a bigger hdd to fit your needs.
    BTW, I saw at a store a USB to IDE HDD cable. I dunno how much but if you combine that with their external HDD power supply, you can attach your HDD to your USB 2.0 port without an external case.
nasira hard disk ko
