Originally Posted by
travajante
Retriculation system is basically plumbing work. The network of perforated pipes must run under, along walls & between to ensure proper termicide dispersion during periodic application. The more inlets & the shorter the pipes between inlets, the better. Ask your architect or builder to lay the system in before you pour your basement or ground floor. Cost will be dependent on structure footprint & total pipe length required....It's not a significant amount relative to total construction cost, ray bai.
