Originally Posted by
brainmafia_310
**sir boybi pala. Kung 22kva genset mo why dont you consider installing ats, may sensing line na ganyang kalaking genset sir. Auto on and auto off na iyan. Bilis pa ng ramp up nyan around 3seconds lang on the 4th may ilaw ka na. By the way, dapat ang connection from main breaker nahati sa dalawa pang sub main, isa para sa lighting at isa para sa outlet at equipment (pwde na to since single phase naman) tpos sanilalim ng sub breaker ng pang eq at outlet may breaker ka para sa motor, ac, ref and etc. Iba iba din breaker ng isang 20a circuit na 2gang outlet. Imho sa main mo na din ikabit ung line for genset for simplicity ikaw na lang magtimple manually ng load kung lalagpas pa sa 22kva ung bahay mo, pero sa tingin ko di mo na mamamaximize yan unles bubuhayin mo lahat at pati lahat ng outlet may nakasaksak na 20a load. Hehehehhe.
Sent from my GT-I9300 using Tapatalk 4 Beta
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
