Results 7,981 to 7,990 of 12332
- May 2018
- 611
August 30th, 2018 01:24 PM #7981Sis, effective ang charcoal as an odor absorber, but very weak siya when it comes to absorbing moisture.
Ako nga, I use the calcium chloride based dehumidifiers and replace/refill them every month- one sa cabin, and the other sa trunk, but sometimes, mataas pa rin ang humidity minsan (70-80%). My small hatchback is a "garage queen" kasi.
Ideally, dapat the humidity should be below 60% to inhibit mold growth, but its hard to maintain here in the Phils kasi humid climate dito. You can by a cheap, medallion sized hygrometer from yung mga Japan home etc. and keep it in your car para ma monitor.
- May 2018
- 611
August 30th, 2018 01:36 PM #7982By the way, if it's cheap uling, as in yung tipong pang ihaw/barbecue na variety from the palengke, and not yung commercially treated/processed activated carbon (although parehong carbon sila of course) baka dun galing yung dormant spores nung mold.
When you put them in your car na humid, well, you just gave them a conducive environment to reactivate and grow...
August 30th, 2018 01:44 PM #7983
August 30th, 2018 01:45 PM #7984
- May 2018
- 611
August 30th, 2018 02:19 PM #7985You need to kill the spores and not just the visible mold.
- Wipe down all plastic/leatherette surfaces with diluted bleach solution and soft cloth (test first in a small area kung may adverse reaction sa material) then after a few min, wipe off with plain water and a damp cloth.
- Remove and wash seat covers then dry them under the sun. If kaya gawin sa carpet, use dry foam cleaner then bilad din.
- If nasa garage naman, open all doors/trunk and air out for a few hours paminsan minsan.
- Pa aircon cleaning ka na rin sa casa/reputable shop (malamang nasa A/C vents na rin yan, so when you switch the A/C on, you'll be blowing spores all over the cabin) and change your cabin filter (not too expensive naman ito, palitan na).
In my experience, hindi gaano efffective ang Lysol spray if may visible mold na, although effective siya from preventing it from spreading- last time I checked, Lysol spray (iba iba ang formulation ng various Lysol products) is merely aerosolized alcohol + fragrance + propellant. Yung concentration nung alcohol in aerosol form is potent enough to only be bacteriostatic and not bactiricidal.
Yung old leather sofa namin sa storage dati, naging fuzzy na sa amag (YUCK. Tumatayo pa rin balahibo ko remembering this... YUCK *shudder*) I gave it a direct spray over ng Lysol. 24hrs later, buhay pa rin yung mga impaktoh, so diluted bleach solution lang talaga nakalinis dun.
- Nov 2014
- 1,269
August 30th, 2018 03:07 PM #7986
August 30th, 2018 03:09 PM #7987
August 30th, 2018 03:29 PM #7988
Just have it detailed. Baka pati likod ng mga interior panels meron na rin molds.
Cath. Tinatadtad ko ng dehumidifier yun mga sasakyan namin pag mawawala kami ng 1 month. As in 6-8 pcs nun nabibili sa ace.
- Aug 2017
- 870
August 30th, 2018 07:51 PM #7989Dehumidifier will help but if the molds penetrates deeply kailangan munang ibilad sa araw ang car all doors ang trunk open to dry off the molds. Then wipe it with bleach diluted with water around 200ppm is more than enough to kill the fungi.
Sent from my iPhone X using Tapatalk
Kung di mo afford ang Ferrari Purosangue , dito kana sa Xiaomi YU7:grin: - - - - - - -...
Xiaomi E-Car
