Results 1 to 4 of 4
    Aug 2003
    this is supposed to be a 3-in-1 device: printer, scanner, and copier.retails for about 5k. owners post your comments naman. thanks
    i have the higher-end cx5300. 3-in-1 din sya. ok naman especially yung ink (durabrite) kasi kahit mabasa, hindi nagba-blot. ang pangit lang sa ink na ito, especially if you print on photo papers, madaling magasgas yung print out. also, since ang durabrite ink stays on top of the paper (not absorbed into the paper like other inks), walang kwenta mag print sa glossy paper dahil nga napapatungan lang yung pagka glossy ng paper.
    mabilis pala ito magprint, mas mabilis pa sa mga older monochrome laser printers.
    Signature
    Aug 2003
    boybi, patanong naman:
    -- ung CX5300 has separate C,M, Y and K cartridges right?
    -- me compatible ink cartridges bang mabibili, or are you stuck with originals?
    -- when copying, relatively fast ba ung pagprint ng copy?(not as fast as photocopiers i assume)
    kung tutuusin, with 5k you can buy a similarly spec'd printer and scanner separately; at least with this you save on space
    yes, separate CMYK cartridges
    hindi pa ako nakapagtanong kung meron compatible ink para dito, pero ito nga yung nagustuhan ko sa printer na ito, hindi nasisira ang print kahit mabasa.
    hindi gaanong mabilis pag copy, mas mabilis ang print from PC.
    also, kayang ma-copy ang buong 8.5x11 na paper, siguro mga 8.25x10.75 lang.
    Signature
epson CX3100: any reviews?
