Results 1 to 10 of 29
June 21st, 2012 10:28 AM #1
pano ba ito? yung kapit bahay naming may mini building open yung bintana nila na tanaw at dikit sa bakod ko. overlooking bubong ng kennel at garage ko diyan sila naglalaglag ng wrappers. nakakawala ng privacy pag ginagawang tambayan ng mga alipin nila, madalas magpahangin. inireklamo ko na nga sa baranggay yung mga nagtatapon at namboboso (sa baba kasi kita yung boobs nung mga maid naming naglalaba). pinag-bibigyan na lang ng esmi ko at mga kapatid kasi kapitbahay bilang pakikisama. kaya lang minsan may nagtatapon ulit tulad ng banana peel.
barbarian kasi ako at taga-bundok kaya di ako puwede humarap ulit sa kanila. mahirap na alam niyo na.
suggestions mga kapatid! salamat!
June 21st, 2012 10:41 AM #2
may mga easements yan
pa inspect mo sa city hall building inspector para gawan ng corrective measures kung may violation
June 21st, 2012 11:03 AM #3
^ tama....hindi ka pwede basta basta maglalagay ng bintana sa gilid ng building...
June 21st, 2012 11:42 AM #5
and pagkakaalam ko there shall absolutely be no openings on/at/within/through all types of abutments (firewalls) erected along property lines except for permitted vent wells nasa xxxxx
pag ganun may violation yan sa building code.... may administrative fine din yan... pero maliit lang parang nasa max 20k lang ata and or less than 2years imprisonment not sure po ha kung covered din yan... baka po nakausap nila yung inspector may inspection din kasi ginagawa ang office of the city bldg. official...
pag ganyan ang permitted vents lang light and view kung tawagin nasa thirty square centimeters lang , and, in every case, with an iron grating imbedded in the wall and with a wire screen pa. then dapat nasa pinakataas pa ng ceiling nila yun....Last edited by glenn manikis; June 21st, 2012 at 12:12 PM.
June 21st, 2012 05:05 PM #6
its in the national building code if you want to know the specifics. if naka firewall yan, bawal ang openings, exemptions are probably mentioned by glenn ^ above. if hindi naka firewall. dapat may easement / offset sila maybe 2 meters from your property. goodluck sir, update mo kami.
June 21st, 2012 06:58 PM #7
kita yung boobs ng mga maid nyo pag naglalaba?
eh, kaya!
btt
dapat ang firewall walang bintana. kaya nga tinawag na firewall eh.
dapat yan solid na pader lang.
June 21st, 2012 07:08 PM #8
mahirap nga yan. nakakailang. biro mo pag labas mo ng garahe pupungas-pungas kapa tapos may nakatanghod na sayo.
June 21st, 2012 07:28 PM #9
June 21st, 2012 07:31 PM #10
