Results 1 to 10 of 17
- Jan 2014
- 54
August 27th, 2018 10:18 AM #1Hi.
I would like to ask kung how many mL or ounce ang magagamit to bleed the brake of Mazda3 (2010 model). There are four disc brakes.
Would you recommend the OEM DOT3 brake fluid? Can you please recommend non-OEM brake fluid that you've used before?
Thank you.
- Jan 2014
- 54
August 27th, 2018 11:19 AM #3
- Jan 2008
- 4,726
August 27th, 2018 12:12 PM #4You can opt to ise DOT 4 type fluid. Compatible din yan sa DOT 3.
It will depend how much you will bleed the system. The smallest can of brake fluid will do. Are you going DIY or have it done in a shop?
August 27th, 2018 03:42 PM #5
Mura lng sa mga shops with their brake bleeders.
- Jan 2014
- 54
August 27th, 2018 06:14 PM #6
- Jun 2018
- 531
August 27th, 2018 06:57 PM #7Is it still recommended to bring sa casa after warranty? Mga magkano ba usually inaabot for 25k km pms?
Sent from my SM-N920I using Tapatalk
- Oct 2006
- 6,282
August 27th, 2018 07:11 PM #8
August 27th, 2018 07:43 PM #9
Check your owners manual. Nakalagay which steps need to be done.
25000km maintenance imo..
-Powertrrain: oil change (correct oil and oil filter), air filter change if required, check for leaks
-ACS: filter cleaning,
-brake system: check and clean
-suspension: check for knocks, uneven tire wear. Tire rotation of required.
- Jun 2018
- 531
August 27th, 2018 07:45 PM #10
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
