Results 1 to 11 of 11
    Aug 2012
    Anu ano po kaya ang mga possible na causes kung bakit bumababa yung rpm at nanginginig yung kotse na parang mamamatay kapag nahihinto? Ano po kaya mga kailangan linisin/palitan? 1997 Mazda 323 1.6 matic po. Thanks sa mga sasagot. 😊
    Sep 2009
    check spark plugs
    Apr 2011
    If its EFI, check servo motor. If it is carb type, check idle up valve
    Sep 2012
    I hope this could help you nakuha ko ito sa workshop manual yung section ng pms schedule and the troubleshooting steps
    http://tsikot.com/forums/showthread.php?t=96357
    Start at page 1 post number 10...
    PM mo na lang email address mo if you want the pdf copy and I double check mo na lang dun if listed yung engine mo.
    Aug 2012
    Quote Originally Posted by jodski View Post
    http://tsikot.com/forums/tech-specs-...ference-96357/
    Wow kumpleto yung thread na cinreate mo boss. Very useful. I'll write it down para alam ko yung mga ipapacheck ko sa mekaniko bago gawin. ��
    Wow kumpleto yung thread na cinreate mo boss. Very useful. I'll write it down para alam ko yung mga ipapacheck ko sa mekaniko bago gawin. 👍
    i had a familia 1.6 before at yung rpm niya pumipitik pitik pag naka idle. daming sinubukan nun. cleaned butterfly valve, replace air intake hose, a few changes ng sparkplug hanggang replace ng distributor. lahat di nasolve. tapos nagspray lang ako ng contact cleaner sa MAF sensor, ayun, after a few runs, OK na.
    Aug 2012
    Quote Originally Posted by coiter View Post
    Salamat po sa reply nyo sir. Anong contact cleaner po ang ginamit nyo at san sya nabibili? Saan po ba located ang MAF sensor ng 323?
    Quote Originally Posted by Troy Inovero View Post
    3M ata yun. almost 8 yrs ago na kasi yun. yung MAF sensor sa familia ay nagdudugtong sa air filter box cover at air intake hose. pag binuksan mo yung box, masisilip mo na siya from the cover. may makikita kang 2 strands of wire sa daanan ng hangin. yun ang sprayan mo ng cleaner. be careful lang na wag matamaan/damage yung mga strand.
    1st time I saw mine, maitim siya. after a few sprays and uses, naging silver.
    Sep 2012
    Troy... na email na yung link sa google drive para sa service manual nito. I will keep the link open for one week only before I remove the document
    Jul 2015
    Pa help naman po, mangyari din po kasi na yung kotse ko po ay may problema din po sa idling flactuating po kc cya at namamatayan po cya pag di naapakan accelerator niya.. yung air filter po niya ay di na po yung stock, naka shimota air filter po cya. Tnx mazda 323 97' model po yung sakin
    Aug 2017
    im new here, i have mazda 323 familia lx, anyone here na may owners manual po? TIA
RPM Drop Mazda 323
