Results 1 to 17 of 17
    Jan 2014
    Hi.
    I would like to ask kung how many mL or ounce ang magagamit to bleed the brake of Mazda3 (2010 model). There are four disc brakes.
    Would you recommend the OEM DOT3 brake fluid? Can you please recommend non-OEM brake fluid that you've used before?
    Thank you.
    Brake? [emoji16]
    Sorry OT ✌️
    Jan 2014
    haha. Thanks at na noticed mo. Holiday break kasi ngayon. Seldom lang to :D
    I'll change it.
    Brake? [emoji16]
    Sorry OT ✌️
    Jan 2008
    You can opt to ise DOT 4 type fluid. Compatible din yan sa DOT 3.
    It will depend how much you will bleed the system. The smallest can of brake fluid will do. Are you going DIY or have it done in a shop?
    Jan 2014
    Sa shop lang. I’ll have the brakes cleaned na rin. Aabot kaya nang 1 liter? I’m planning to buy ahead before going sa shop.
    Thanks.
    Jan 2008
    Quote Originally Posted by bboyukoy View Post
    Thanks.
    If you want to flush the system with fresh fluid 1L will do. Otherwise 500ml is enough
    Mura lng sa mga shops with their brake bleeders.
    Jun 2018
    Is it still recommended to bring sa casa after warranty? Mga magkano ba usually inaabot for 25k km pms?
    Sent from my SM-N920I using Tapatalk
    Quote Originally Posted by thenightcrawler View Post
    My Mz2's Yojin expired last month. I asked the SA how much is the PMS, he said between P5-7k. I suppose thats the ballpark figure for all Mazda cars.
    Check your owners manual. Nakalagay which steps need to be done.
    25000km maintenance imo..
    -Powertrrain: oil change (correct oil and oil filter), air filter change if required, check for leaks
    -ACS: filter cleaning,
    -brake system: check and clean
    -suspension: check for knocks, uneven tire wear. Tire rotation of required.
    Jun 2018
    Thanks, I 'll check. Pero OK lng ba ndi na yan sa casa gawin? What Would you recommend?
    Some shops kasi meron lifters. They'll be able to replicate casa maintenance. Some shops like motech do have checklists and lifters.
    Mar 2004
    Both brake and break are correct ... some regions use break ...
    Jan 2016
    Hindi ba presyong casa din ang motech? Sa motortown San pedro, laguna ba yung pavillion mall?, sila ang pinakamataas na change oil rate. 500 IIRC, that was years ago, when every one was doing 200-300.
    Jan 2014
    My suggestion for M2 and M3 is for ATF, sa Mazda na. Sa engine oil, sa other shops na with branded but still less expensive sa labor. Based sa na research ko on other Mazda forums, there were cars having issues because of using different ATF.
    I would suggest din yung may lifters so that you can check your under chassis. I usually take photos and videos with flash on pag madilim tapos I review sa computer at home. Just in case I miss something during sa inspection.
Mazda3 2.0 break bleeding
