Results 11 to 20 of 26
August 27th, 2016 09:57 AM #11
Yes sir that road is passable, medyo masikip lang since my mga nka park dyan ng mga tricycle sa tabi ng daan.
Another option is you take a right turn sa munispyo ng los baņos papuntang jamboree, that road will lead you UPLB campus, traverse pili drive, turn right before irri gate, follow the road or waze mo lang sir, ang labas mo na dyan sir ay bay, laguna.
Kung ayaw mo sir ng masikip na daan take this road. If you don't mind na masikip ang road and you want a shorter route, follow mo sir yung map. Hope this helps
- Nov 2015
- 31
August 27th, 2016 05:39 PM #12Salamat po sa lahat ng inputs nyo
Next problem is kung saan masarap kumain sa lucban any suggestions po?
August 27th, 2016 06:03 PM #13
Try Samkara in Lucban Majayjay boundary. I had tried it just yesterday and they have good crispy dinuguan, laing. Don't order crispy pata, not good.
If you can extend a bit, try kamayan sa palaisdaan in Tayabas, go for the original one. The better one is on your right if you are going to Tayabas town proper. Also, a few hundred meters is Air Summit Gourmet, they have this 737 (?) airplane that was converted into a resto, but the food is so so, but a good for photo ops.
August 27th, 2016 06:11 PM #14
August 27th, 2016 06:15 PM #16
- Jul 2013
- 2,450
August 27th, 2016 06:16 PM #17
August 27th, 2016 06:17 PM #18
August 27th, 2016 06:21 PM #19
In which case, the mountain road from Pagsanjan Cavinti (Majayjay) Luisiana is one great drive... one hour of non stop zigzag... Highly recommended but be very careful.... madulas ang kalye lalo ngayon na umuulan... Diyan din ako nakaengkwentro ng poging mga tao, - twice...
- Jul 2013
- 2,450
August 27th, 2016 06:22 PM #20Kung sobrang trapik sa Pansol, Calamba (as in 10kms in 2 hours tsk tsk), pwede via Sto. Tomas then turn left towards MakBan power plant. Bayan ng Bay, Laguna ang tutumbukin niya so towards Pagsanjan pa din.
Google Maps
