Results 1 to 13 of 13
    Oct 2005
    Hi, Whats the Best route from pampanga to Araneta Coliseum? 1st time ko palang Dadaan sa Edsa.
    Nov 2007
    Take the North Luzon Expressway till you reach Balintawak, you may use EDSA or take the C-3 Araneta Ave. route.
    If you take Edsa from Nlex go up the Balintawak cloverleaf, then just go straight to Edsa, till you reach P.Tuazon in Cubao Q.C., not sure if you could take a U-turn but if not then take a left at P. Tuazon straight then make a left if you see the SM Shoemart, you are entering the Araneta Center compound na.
    If you take the C-3 Araneta Ave. route then from NLEX straight to Bonifacio Ave., there is no left turn from Bonifacio Ave. to C-3 Araneta Ave. so you have to cross the stoplight then make a U-turn at the next stoplight, turn right to C-3 Araneta Ave. straight lang till you reach the E. Rodriguez Blvd., landmark is the Puregold Priceclub Q.I., make a left straight till you reach EDSA cor E. Rodriguez Blvd., cross that intersection then just look out for the Welcome to Araneta Center Arch (1st or 2nd block from the stoplight), make a right and there you are. Good luck.
    Oct 2005
    Quote Originally Posted by ans_lim168 View Post
    Salamat sir, siguro sa C-3 Araneta ave route nalang ako.. Salamat ulit
    Feb 2005
    malayo yung a. bonifacio- c3 road. best would be EDSA.
    Take Edsa Aurora service road ( commonly known as Cubao Ibabaw sa mga signage ng buses) left turn sa aurora. tapos kanan sa may gateway.
    Sep 2005
    may left turn ba don sa aurora?
    another option kung trapik sa Edsa is.. u turn sa may Trinoma, then go via North Avenue.. then elliptical.. then pasok nang Kalayaan.. diba Tuazon na din ang labas non. then alimall na..
    Feb 2005
    minsan meron, minsan wala. depende sa naka poste
    Dec 2007
    Manonood ka ng Game 4 (PBA)? hehehe.
    Anyway, pwedeng huwag ka nang mag-U-turn along A. Bonifacio just to go back to C-3, just take the Del Monte Ave. left turn, then turn right at Araneta Ave. and follow the rest of ans_lim68's instructions.
    Good luck! Huwag magpapahuli sa mga buwaya!
    Feb 2006
    Quote Originally Posted by toast View Post
    cabalen, from nlex take edsa, left turn ka aurora blvd (take the ibabaw route) pwede private vehicles/ just stay away from yellow lane. then right araneta centre na
    IMO, on EDSA its better to take all the Cubao underpasses then after the P. Tuazon underpass, go under the EDSA - Santolan flyover then take the U-turn slot before the intersection and go up straight to P. Tuazon. After the P. Tuazon intersection, there's an access road that takes you into Cubao/Farmers then go straight to Gateway to park.
    Another option is to park in Trinoma then take the MRT to Cubao. It's all enclosed walkways through Farmers to get to AC.
    Dec 2008
    nagpunta din ako sa araneta galing bataan naman, at ako nagdrive. Sa edsa ako dumaan then turn left sa aurora (cubao ibabaw), naligaw pa nga ako nung una sa ilalim ako nadaan di ako nakalipat lane sa trapik (lakas ulan di makita signs tapos first time pa ko dumaan dun by car) at inaabot pa ako sa ortigas tapos u-turn sa meralco , ayun huli bawal pala. Kotong moments. dapat nagbus na lang ako hahaha.
    tapos na-cut at sinagi pa ko ng dilaw ng vios taxi. Bwiset na taxi yun, sabay harurot ang kumag at tinakbuhan ako. Swerve dito swerve doon, palibhasa puro gasgas na taxi nya. Nalagyan tuloy ako ng gasgas at dilaw na pintura sa front fender
Pampanga to Araneta Coliseum
