Results 1 to 6 of 6
August 18th, 2009 09:10 AM #1
currently taking the c5 then SLEX
baka may iba pang way, same fuel consumption but without the toll fee
any suggestions ka-tsikotistas?
thanks!
August 18th, 2009 11:52 AM #2
pag galing ako sa mga inlaws ko (from diliman), i usually take C-5, go inside the Fort, go out of EDSA, airport road. pero las pinas lang ako eh.
i think that from C5 to alabang, walang ibang alternatives except SLEX. mapapalayo ka kung mag via-las pinas or sucat ka. and besides, you need to have some village stickers too.
August 19th, 2009 06:32 PM #3
i usually take the east service road.
from marikina, i take c5 from end to end. when i reach the forked entrance to slex, i hang a right going to the service road.
the service road goes all the way to alabang (in the vicinity of metropolis mall).
with the slex construction going on, sometimes i breeze through the road while cars on slex are at a standstill.
PROS: you save around 66ish++ bucks toll, distance is more or less the same because you're travelling parallel to SLEX
CONS:
usual vein-popping bottlenecks are bicutan, *&%^$*& jeepney stops, pedestrians, bikers, and slow trucks. the two-way situation can be a major stressor at times as well.
cheers!
September 4th, 2009 12:20 PM #4
September 4th, 2009 12:45 PM #5
SLEX is really the easiest.
The service road trick works only sometimes... during rush hour... at other times, you will be stuck for half-an-hour or more on the service road while jeepney drivers block both lanes of traffic picking up and dropping off passengers. And if you're unlucky enough to be behind a jeepney that's stopping at a construction bottleneck...
There's hope in the upcoming C6 project that will go around the Laguna Lake area... but that's years from completion, sadly.
September 4th, 2009 01:45 PM #6
VinFast VF 3
