Quote Originally Posted by ambasad0r View Post
^ hahah. Iba nga po yun sir.
Sino po may alam jan?
Take Cavitex then exit sa dulo. Go straight along the highway crossing all the intersections then there will be a right turn (still along the highway, just follow the highway divider lines) at the Maragondon area. Next will be a similar left bend pero still going along the highway tapos paakyat na ang kalsada. You will pass by Puerto Azul, then there will be a left turn that you won't miss na may "to nasugbu" sa gitna ng bundok. Turn left then you will go through the Kaybiang tunnel then puro pababa na yun (Sa Caylabne ka babagsak if you go straight). Once patag na, there will be a right turn pagdating sa Looc but the right turn is still going along the highway (always take the bigger roads). After a while malalampasan mo yung Punta Fuego then magiging paakyat ulit yung daan. You will reach nasugbu in no time pag pababa na ulit yung kalsada and you will see Canyon Cove to your right.
Yes mas mabilis doon and very scenic ang route paglampas na ng puerto azul.
