Results 1 to 8 of 8
- Jan 2006
- 191
September 27th, 2006 10:13 AM #1swak ba ang gulong na 185/65/r14 sa rims na currently having a tire na 175/65/r14??kasi meron sa akin binebenta na rims..pero 175 nkasalpak sa kanya ngayon..concern ko lang is yung lapad.baka di pumasok..eh parang sobra nipis na ng 175 sa ek..meron nko tires na 185/65/r14..sayang nmn kung di ko yun gagamitin..tulong naman kung swak yung tires ko..
- Sep 2005
- 102
September 27th, 2006 10:59 AM #2Based on michelin website recommended rim width for 185/65R14 tyres are the following: Min = 5.0", Optimum= 5.5", and Max = 6.5". So to be safe check mo muna yung Rim Width nya.
- Jan 2006
- 191
September 27th, 2006 11:23 AM #3Based on michelin website recommended rim width for 185/65R14 tyres are the following: Min = 5.0", Optimum= 5.5", and Max = 6.5". So to be safe check mo muna yung Rim Width nya.
September 27th, 2006 01:08 PM #4
Most 14" rims are at least 5" wide. It shouldn't be a problem.
The measurement is in inches of the surface where the bead sits, if you measure from outer lip to inner lip, it won't be exact, but it should give you a good estimate.
- Sep 2005
- 102
September 27th, 2006 02:34 PM #5Usually its in inches. For quick reference you may check on the website below:
http://www.tireguides.com/tip10.html
http://www.tireguides.com/tip18.html
September 27th, 2006 04:09 PM #6
- Jan 2006
- 191
September 27th, 2006 05:15 PM #7so basically di ko kelangan mamroblema??kahit 185 gamitin ko na gulong??
September 27th, 2006 05:33 PM #8
Yup. Tire size only becomes a problem if you're upgrading to 205 or larger. At 205 you'll need at least a 6.5 - 7 inch wide rim. Up to 185, any standard 14x5 rim is just fine.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
