Results 1 to 10 of 38
- Oct 2006
- 41
October 18th, 2006 04:02 PM #1where can i get a 18X9 +30 offset for front and 18X10 +25offset? saan ba ang pina ka mura na ma kukuhaan ng rims
October 18th, 2006 10:47 PM #7
rota P45R ata meron ganong sukat...
http://www.rotawheels.com/products.php?id=68
October 19th, 2006 05:46 AM #8
since you can afford a Z don't cheapen out on wheels. 18x10.5 can fit in the rear.If you're on the budget get an enkei nt03.Best mod for your z is test pipes since walang emission test sa pinas then get jim wolf tech air intake and crawford plenum,you'll be amazed.PM me if you need to make your Z go fast.Sibakin mo yung mga NA porsche dyan.
October 19th, 2006 06:30 PM #9
May emissions test naman, but I bet, even with a test-pipe, the Z will pass.
ROTAs aren't bad, but the P45R is only available in one offset, mas maganda talaga ang staggered.
There are locally available EVO rims (not sure if they're Silverwind) that have a staggered offset, and they're in 18", but I don't know if they're wide enough.
Alternatively, you can look at Tire Rack (no, not THE Tire Rack, just... Tire Rack) on Ortigas, just turn right at the Ortigas intersection coming southbound from EDSA, it's right before La Salle... lots of big-sizes there.
Also, you can try Tireboy (hope that's right) in Banaue, as they have lots of big size wheels, but most of them are sized for European stud spacing.
October 19th, 2006 06:38 PM #10
try www.importhookup.com also. you can make an indent order for certain wheel brands like work, volk, and 5zigen. you can also try emperor in home depot ortigas. they have a set of volk g-games on display din ata.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
